After stripping, how soon do I have to paint? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-30-2013, 07:58 AM Thread Starter
AMT1379's Avatar
I'm doing frame-on work on my driver and trying to plan out the exterior paint for next summer/fall, which I think is next phase of work.
Aside question, which first, interior paint or exterior paint?
Details for the exterior work:
The car is. sadly. now living in a portable garage, in the rust friendly Northeast.
I bought the car in primer 15 years ago and had a cheapo maaco job done on it to protect it a bit more, about 13 years ago.
I know I have a rust bubble on the hood, and some small areas of rot on the rear wheel wells.
Given my resources, stripping will likely be a combo of sanding and chemical stripper.
When I strip, I know to expect a significant amount of body work that needs to be done. After reading your war stories, I know the issues I see now are just the tip of the iceberg.
So the questions I have are:
Do I strip in phases, hitting the likely problem areas (wheel well, windshield, hood) first so that I minimize exposure time on the rest of the sheet metal?
After stripping, do I have days, weeks, or months to complete the body work and get in in for paint, before exposure would create new problems, or make the problems potentially worse?
Rumble Rumble Rumble
AMT1379 is offline
post #2 of 7 (permalink) Old 08-30-2013, 09:26 AM
Quoted: 98 Post(s)
After stripping, rust starts in minutes, not days. Had a car stripped in arid CA and treated with metal prep immediately. It took ten years, but rust came back through the paint.
post #3 of 7 (permalink) Old 08-30-2013, 10:06 AM Thread Starter
AMT1379's Avatar
So, "it is what it is"? Just strip the whole exterior?
AMT1379 is offline
post #4 of 7 (permalink) Old 08-30-2013, 02:27 PM
Quoted: 98 Post(s)
I would do a small section at a time.
post #5 of 7 (permalink) Old 08-30-2013, 04:47 PM
I would strip one section at a time, treat with a rust preventative like ospho and prime with an epoxy primer. Then you will be ok to work on the panels at your own pace and paint when you get ready.
JMHO,
05GTO is offline
post #6 of 7 (permalink) Old 08-30-2013, 06:25 PM
Quoted: 22 Post(s)
1 panel or area at a time, immediately spray on a rust preventative after wiping clean get a coat of epoxy over the whole panel ASAP, then you can start the filler and body work on the epoxy. Epoxy provides better grip to the metal than filler, and the filler will bond better to the epoxy then bare metal and epoxy seals out any moisture.
Instg8ter is online now
post #7 of 7 (permalink) Old 08-30-2013, 08:53 PM Thread Starter
AMT1379's Avatar
Great, thank you! I'm a little nervous to start screwing with the paint and body, but the car really needs it. And, as I've indicated on other posts, I'm can't stand to cut bait with this car any longer, I need to move forward or sell it. I just turned down an offer that was probably fair, so...onward in to murky depths I go!
AMT1379 is offline
Stripping car A4GTOMAJOR 2004-2006 GTO General Discussion 19 02-01-2011 08:53 PM
Stripping The Rear End sixeightGTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 09-06-2010 06:43 PM
Enduro bumper paint stripping firecatsrt 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 11-30-2009 07:15 AM
Stripping a Denali..... GTODEALER The Lounge 14 11-30-2005 06:04 PM
chrome stripping suspect The Lounge 4 05-05-2005 01:16 PM
