Chassis paint - Pontiac GTO Forum
post #1 of 28 (permalink) Old 05-06-2010, 12:07 PM Thread Starter
Chassis paint
I am sure this topic has been discussed to death but I am putting it out there.
Just got the frame back from sand blasting and want to paint it. Any suggestions on what is the best product to use and why.
DrBoeing is offline
post #2 of 28 (permalink) Old 05-06-2010, 01:35 PM
I've had success with most of the Eastwood products;
Underhood paints - Paints
05GTO is offline
post #3 of 28 (permalink) Old 05-06-2010, 01:38 PM
y2kjammer's Avatar
Up under the 'search' dropdown bar type in frame paint (or something of that nature. You will find a number of different threads that will answer your questions. It's all good reading.
y2kjammer is offline
post #4 of 28 (permalink) Old 05-06-2010, 01:41 PM
NAPA carries Martin Senor Paints with their NAPA name on it, their underhood paint is the exact same color as Eastwoods for far less money. I had some Eastowood underhood paint and ran out and got NAPA's the colors were identical and the flow was nice and even.
Duplicolor paints go on nice too, I used their Engine paint and it works great.
post #5 of 28 (permalink) Old 05-06-2010, 02:55 PM
Quoted: 98 Post(s)
Originally, from what I've researched, the frames had a thin coat of blackish paint that rubbed off easily. Both of my unrestored cars have what looks like bare metal frames. Maybe a slight hint of black paint here and there. Every non restored original GTO frame I've seen looks like mine: bare. if I were to due a frame off, I would probably use Rustoleum semi-goss or low gloss black. I've used it on diffs, suspension parts, and my Model T frame, and the stuff looks right, is cheap and available, and it tough. Your mileage may vary.
post #6 of 28 (permalink) Old 05-09-2010, 10:40 AM
crustysack's Avatar
depends if your doing concours or you want it to last. if the latter try POR-15 a 1 part paint that actually get harder when exposed to moisture- I am in the north east where cars rot- I did not want this to happen to this car (65) after restoration so I did some research and was also turned onto this product by my tech who swears by it. If you are not going to powder coat this is the next best thing- I did the frame,diff, the whole bottom of the car, firewall, radiator support, inner fenders, and any thing else I could slap it onto. Its about $130 per gallon but I did all those parts with 1 gallon- if you only are doing the frame 1 qt is PLENTY. All of those parts were brushed no spraying. I went with gloss for easy cleaning but they also make flat and semi gloss and different colors.
ID:	7377   Click image for larger version
ID:	7378   Click image for larger version
ID:	7379   Click image for larger version
ID:	7380   Click image for larger version
crustysack is offline
post #7 of 28 (permalink) Old 05-09-2010, 10:47 AM
The non-gloss black spray cans from NAPA is the correct color. But that POR 15 does look good, and even though it's not correct, I see cars with it win more at the shows then the correct cars.
post #8 of 28 (permalink) Old 05-09-2010, 05:47 PM Thread Starter
Did you use just the regular Por 15 or did you add a top coat for UV protection
DrBoeing is offline
post #9 of 28 (permalink) Old 05-09-2010, 07:00 PM
crustysack's Avatar
I used regular everywhere and I believe I top coated the area in the engine bay- the rest of the areas will never be hit by sunlight
post #10 of 28 (permalink) Old 05-10-2010, 08:02 PM
I'm asking the same question myself on another post. Check out Inline Tube - Preformed Stainless & OEM Brake Line Sets That's the way to do it. I just need to no what products to use and on what parts. Let me know if you find out.
masterblaster is offline
My new chassis for the 67 GTO Eric Animal 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 17 03-10-2010 06:50 AM
Chassis number 1969GTOConv 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-06-2009 05:47 PM
Good Paint! (Bad Paint? part 2) Rukee 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 8 06-20-2008 09:13 AM
Paint Splotches+Failed Heat Gun = New Paint Job!! undertaker Service, Maintenance and Technical Discussion 3 07-07-2006 09:14 PM
Best 60 % Chassis Black Paint? judger70 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 1 03-18-2006 08:23 AM
