Correct Black for Under Hood Heater Box - Pontiac GTO Forum
 1Likes
  • 1 Post By GTOJUNIOR
post #1 of 7 (permalink) Old 01-31-2018, 06:40 PM Thread Starter
For a '67 GTO with AC (if that matters) is the under hood heater box a gloss black? Or some degree of semi black?
Andrew69 is offline
post #2 of 7 (permalink) Old 01-31-2018, 11:22 PM
Everything in the engine compartment that is black is a 60% gloss black, only the underside of the hood is 30% gloss black,
05GTO is offline
post #3 of 7 (permalink) Old 02-01-2018, 04:53 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
The Firewall was blacked out as they say, before all the front end components and bolt on parts came together.
While the transition point on the fire wall of black varied greatly Plant to Plant,
some stopped at the Body seam and others went straight across the top of the cowl.
That said you will always see a difference in "GLOSS" between the Firewall & Bolt-On parts, i.e. Air Box. Inner Tubs and such.
To generalize it all one color in not really accurate.
The black-out is a low gloss while the other component since painted separate during the assembly process are more or less Semi to gloss.
Underside of the hood also follows the firewall Black-Out " Degree of gloss.
Take some time and search for True Survivors for reference and you will start to notice the varying gloss under the hoods.
Avoid HIGH GLOSS like so many of the over-restored show queens.
JM2C
CHEERS
1968gto421 likes this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 7 (permalink) Old 02-01-2018, 05:36 PM
Quoted: 350 Post(s)
If you read through this, it may help: https://www.gtoforum.com/f12/gtoaa-co...ds-pdf-126401/
post #5 of 7 (permalink) Old 02-02-2018, 07:17 AM Thread Starter
Yesterday I sand blasted the air box and it's ready for primer and paint. Today I will pick up some Rustoleum satin black 7777 that is about 70% gloss.
I found the single port actuator on the car was completely trashed. The bellow is dried and crumbled. Now I am wondering the condition of the bellows under the dash. Should I also remove the under-dash heater/air box to check those parts?
The snowball is rolling ......
Andrew69 is offline
post #6 of 7 (permalink) Old 02-02-2018, 08:24 AM
For color reference:
60% black. Satin/Semi.
post #7 of 7 (permalink) Old 02-05-2018, 07:16 AM Thread Starter
Thank you both for the information.
Andrew
Andrew69 is offline
69 judge heater box greenjudge69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 02-01-2017 08:30 AM
Inner heater box removal gnsjoy 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 11-03-2014 08:47 PM
65 GTO Heater Box Heater Core Blower Motor Questions WideTrack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-06-2013 07:45 AM
heater box seals for '67 GTO with A/C TommyG67 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 02-02-2012 09:42 AM
What is the correct finish for 69 steering box? steampipe 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-20-2006 07:32 PM
