Dumb question - Pontiac GTO Forum
 2Likes
  • 2 Post By PontiacJim
post #1 of 2 (permalink) Old 10-09-2019, 04:49 PM Thread Starter
Dumb question
Mates,
I have a 1967 GTO that is nearing completion (I hope) of the metal work (both quarters had some rust and both hinge pillars). I am anticipating dustless blasting next spring. Is the next step then application of a primer or filler? I assume there won't be any new areas to do metal work, but not counting on it.
I just need to plan for next spring and getting together the timing if immediate priming is required. It will sit inside and will be a driver, not a show car.
Any thoughts welcome.
JD
JDskibum is offline
post #2 of 2 (permalink) Old 10-09-2019, 08:15 PM
Quoted: 404 Post(s)
Originally Posted by JDskibum View Post
Mates,
JD
I would first prime the bare metal to protect it so you won't develop any surface rust. Then go back over those areas you want to do your filler work (assuming you are talking about bondo), and grind the primer off to bare steel and begin your work.
You don't want to leave the car in bare metal for very long. Moisture, humidity, temp changes, etc. will have it rusting pretty quick.
Bobbyg and 1968gto421 like this.
