Engine Paint -- What Color and Who Sells - Pontiac GTO Forum
post #1 of 11 (permalink) Old 07-11-2009, 09:06 AM Thread Starter
Where can I find the correct color for a 67 Pontiac motor and who sells a good quality high temp paint? Is the same color used for the tranny as well?
bkellis1 is offline
post #2 of 11 (permalink) Old 07-11-2009, 11:04 AM
This was posted up by another forums member and i saved it.
Pontiac Engine Colors
Tranny was not painted.
post #3 of 11 (permalink) Old 07-11-2009, 11:27 AM
I used 500 degree Plasti-Kote 227 Pontiac Metalic Blue on my engines and sprayed the transmissions with aluminum spray paint,
05GTO is offline
post #4 of 11 (permalink) Old 07-11-2009, 11:48 AM Thread Starter
Wow. That looks fantastic!
Where can I get the Plasti-Kote brand paint and how much can I expect to pay?
And hey, thanks for the link. This looks to be very helpful. Much thanks!
One other question -- will I need to use primer?
bkellis1 is offline
post #5 of 11 (permalink) Old 07-11-2009, 02:09 PM
You can find it at Performance Years for $6.00 a can, if you use a primer use a high heat gray like Plasti-Kote 228 for engine and transmission, click on the picture
Also, Year-0ne sells Dupli-Color for a little more
05GTO is offline
post #6 of 11 (permalink) Old 07-11-2009, 11:14 PM Thread Starter
Cool. Thanks for the info.
bkellis1 is offline
post #7 of 11 (permalink) Old 07-12-2009, 09:09 AM
allpawl66's Avatar
In my opinion that is the wrong shade , Gm used a greener tint of paint for that year.
allpawl66 is offline
post #8 of 11 (permalink) Old 07-15-2009, 12:30 PM
Quoted: 98 Post(s)
It is the correct shade. It will turn slightly greenish after years of hot/cold cycles. I overhauled my '67 in 1988, and did a cyl. head swap last year. I still had paint left over from the rebuild 20 years prior, so I used it on the new heads. It was noticeably more blue than the block. But, it will change a bit in the next few years. Like ivory....mellows over time.
post #9 of 11 (permalink) Old 07-15-2009, 09:21 PM Thread Starter
Is it advisable to use primer when painting an engine?
bkellis1 is offline
post #10 of 11 (permalink) Old 07-16-2009, 02:05 PM
Quoted: 98 Post(s)
I never have. The factory didn't.
