Frame paint - Pontiac GTO Forum
post #1 of 10 (permalink) Old 06-09-2010, 08:35 PM Thread Starter
Frame paint
I am repainting the frame on my car what is a good paint to use. i am going for the factory finish appearance but i also want something fairly durable as well. What paint works well for suspension components.
diesel_man is offline
post #2 of 10 (permalink) Old 06-09-2010, 08:42 PM
I painted both of mine with rustoleum, I mixed 40% flat with 60% gloss to get the factory 60% gloss. I believe Rustoleum also has a satin that some say is pretty close.
05GTO is offline
post #3 of 10 (permalink) Old 06-11-2010, 05:38 AM
Cpldavis37's Avatar
I am going to use POR15, but it does not look factory.
Cpldavis37 is offline
post #4 of 10 (permalink) Old 06-11-2010, 09:56 AM
ponchonorm's Avatar
I used Valspar Tractor and Implement low gloss black on my 65. Takes a while to dry but when it does its tough. Barely even scuffed my lower control arms prying the new springs in.
ponchonorm is offline
post #5 of 10 (permalink) Old 06-11-2010, 06:21 PM
67 Basket Case Restorer
Too Many Projects's Avatar
Eastwood has a Ceramic particle, epoxy paint that comes in Gloss or Satin Black. I used the Epoxy Spray Gray, as I don't care for black frames.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #6 of 10 (permalink) Old 06-12-2010, 08:57 AM
crustysack's Avatar
TMP I like the look of that-looks like metal yet painted- I'd go with that color next time I do the frame off resto
crustysack is offline
post #7 of 10 (permalink) Old 06-12-2010, 09:12 PM
I used por15 plus a top coat and it turned out very nice.
https://www.gtoforum.com/f50/chassis-paint-26896/
DrBoeing is offline
post #8 of 10 (permalink) Old 08-02-2012, 08:30 PM
Deltrom 9700
I used Deltron 9700.
EP Goat is offline
post #9 of 10 (permalink) Old 08-03-2012, 07:52 AM
I'll second the vote for Eastwood's Ceramic Chassis paint. I used the semi-gloss and LOVE the look. Also, it was pretty easy to use. I did sandblast my frame first and had clean metal to work with. I also used it on the control arms too. I haven't chipped it yet! Here are some photos of my result...
ID:	15392   Click image for larger version
ID:	15393   Click image for larger version
ID:	15394   Click image for larger version
ID:	15395   Click image for larger version
digitalmanchris is offline
post #10 of 10 (permalink) Old 08-03-2012, 01:09 PM
Wob
Mine is Eastwood Extreme Chassis in 60-70% gloss. I have used it many times and I love it.
Wob is offline
67 frame (chassis) Eric Animal 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 02-10-2009 09:36 AM
Good Paint! (Bad Paint? part 2) Rukee 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 8 06-20-2008 09:13 AM
'66 vs '67 Frame Tempest625 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 04-03-2008 02:52 PM
Paint Splotches+Failed Heat Gun = New Paint Job!! undertaker Service, Maintenance and Technical Discussion 3 07-07-2006 09:14 PM
