Help! Correct paint for interior - Pontiac GTO Forum
post #1 of 6 (permalink) Old 04-28-2014, 10:47 PM Thread Starter
I'd like to buy the correct paint to restore the interior door panels. Where can I get it??
Berto504 is offline
post #2 of 6 (permalink) Old 04-29-2014, 03:35 PM
67Twistytee's Avatar
Both Ames Performance and Performance Years carry the interior vinyl dye paints that can also be used on the metal trim. If you call them, I believe they will send you samples in order to get a match. I believe they are Omni Pak GM reproduction colors. Omni Pak is owned by the Krylon Products division of Sherwin Williams, so you might be able to go to local store with a high quality photo for a match.
I have a different color interior than you but used a spray can from Ames that was a close match.
67Twistytee is offline
post #3 of 6 (permalink) Old 04-29-2014, 06:17 PM
tiger13's Avatar
Hi Berto504
I just got done ordering interior paint for my 67 from this place Color Chip Selection
It aint cheap and it took about 10 days total to get to me in NC, they are in California, 5 days to make it, 4 days to ship it, I got 2 Qts, 1, flat black, 1, 60% gloss, and some hardener with the shipping it was $114. I could NOT get this stuff from any place near me, I tried everywhere so I guess I was stuck. The places that mixed paint near me would not even try , as they had no formulas to go by. So, it is what it is. Hope this helps for you
tiger13 is offline
post #4 of 6 (permalink) Old 04-29-2014, 07:41 PM Thread Starter
His did your paint job come out?
Berto504 is offline
post #5 of 6 (permalink) Old 04-29-2014, 09:51 PM
My interior is original but in good shape (driver quality not concourse). It only required some minor touch-up on the upper door metal driver side. The Ames interior paint worked well for this purpose. It looks like yours is dark metallic green/turquoise which maybe a little tougher to match. I would recommend calling Ames or Performance Years and giving them your interior color code to see if they can send you a color chip.
If you have a lot of area to cover or are looking for a near perfect match, you may need to go the route suggested by tiger13 and find a shop that will mix to suit. I have also read that SEM automotive paints have been used by others with success. I believe Summit carries these as well as other online vendors. Hopefully someone else who has experience here will weigh-in.
Andy
'67 GTO/Signet Gold over Parchment/Pontiac Built
post #6 of 6 (permalink) Old 05-05-2014, 05:43 PM
It would be better if I knew where you are, but some professional jobbers that mix paint (PPG or DuPont) may have the interior color in their mixing data. I prefer PPG over anything else, even if the other was 1/2 price. So, going by that I'd recommend PPG's Shop-Line product and order what you need in basecoat. Also get 8oz of DX57 hardener. You mix the base and add a cap full to a ready to spray QT (paint and reducer, 50/50). This will net a low gloss and durable catalyzed finish. The other option would be be clear urethane with about 25% flattening agent, but you really don't need the clear if you add the 57 to the base, especially since it's the inside. A qt of base gives you 1/2gal ready to spray. The color doesn't appear to be that difficult and there's probably an exterior color from a current car that would work well too. Hope that helps.
666bbl is offline
1964 correct console paint mikey9743 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 1 06-29-2013 02:27 AM
Correct firewall paint color 65 GTO pbertrand65GTO 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 0 01-31-2012 05:37 AM
1965 Engine Paint - need correct color torpedo51 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 10 09-07-2011 07:53 PM
69 GTO - Taillight Panel - Correct paint? BearGFR 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 3 05-23-2011 08:37 PM
Correct Paint texture for underdash--? Craig 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 3 01-14-2008 04:54 PM
