need the right paint code for dark sandalwood - Pontiac GTO Forum
post #1 of 2 (permalink) Old 03-01-2009, 12:13 AM Thread Starter
skapegoat's Avatar
i have tried 3 or 4 different over the counter interior paints and none of them matched. i even took the column to the ppg dealer and they couldn't get it right. i need the universal code for dark sandalwood 0 golss. the codes i have are dupont 9704-l, ditzler 23311, rinished mason 170B50R. it is for the dash. i am also not sure what would be the best mothod of applying it. spray can, single cote, 2 stage?
some may say i have too many projects
skapegoat is offline
post #2 of 2 (permalink) Old 03-01-2009, 07:38 PM
67 Basket Case Restorer
Too Many Projects's Avatar
You don't want the 0% gloss for the column, you need the low gloss, often referred to as 60% gloss. That Ditzler number is 23324. Remember the paint on there now has probably faded and may look light next to new paint. If you're going to paint everything, it will all match anyway. The best method to apply would be a gun and a bc/cc application although getting it in a spray can would be easier.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
18" Wheel Paint Code DuaneGTO Wheels and tires 5 07-14-2009 03:17 PM
Intake Manifold Paint Code 1965 GTO pjshortt 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 5 01-28-2009 02:59 PM
GM paint code deg04gto Exterior Discussions 3 10-30-2008 11:36 PM
GM Paint Code for 2004 Yellow Jacket? Groucho Service, Maintenance and Technical Discussion 3 10-19-2005 12:20 PM
