paint - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-13-2015, 05:52 PM Thread Starter
paint
has anyone used the
restoration shop paint kit for $300, just wondering how good it is.
I want to paint my 67 gto burgundy but don't know witch paint to use, first timer. thanks Jim
jim w is offline
post #2 of 11 (permalink) Old 03-15-2015, 06:19 AM
Hey jim,
All the keys to getting a good paint job are what happens before and after you do the spraying (especially the before part). The spraying itself really isn't that much of it. However, you DO need to be very careful about material compatibility. Today's finishes are designed to chemically cross-link between layers, so it matters a lot that everything from the bare metal "up" is compatible with each other, and timing also matters too. Lots of products have a "recoat window" - meaning that once you start laying them down, you MUST apply each successive coat within a defined time interval, otherwise you won't get the chemical bonding and you have to sand and start over.
Let me recommend to you a set of videos, available here:
Kevin Tetz's Paintucation OFFICIAL SITE
That's what I used to learn when I painted my '69, and I had never painted a car before in my life. It turned out ok
post #3 of 11 (permalink) Old 03-15-2015, 12:24 PM
Quoted: 98 Post(s)
jim, what Bear said. Research, research, research. A friend and I pained my '67 in 1993 with single stage PPG urethane enamel. Very small metallic particles. I spent 40 hours cutting and buffing it, (before I knew you weren't supposed to cut and buff metallic single stage) and it came out very well....except for the sanding dust that I forgot to blow out of the windshield channel that ended up on the driver's front fender! Still looks good after 22 years, though. The one thing I did was go with 1968 Flambeau Burgundy, which is significantly darker than the standard Burgundy of 1967. I like it better. Your taste may vary. The more research and homework you do, though, the better. You will save time and MONEY. Keep us posted!
post #4 of 11 (permalink) Old 03-21-2015, 06:45 PM
If you're going to do it yourself, do a wrap
FMFC motorsports is offline
post #5 of 11 (permalink) Old 07-26-2015, 08:15 PM
Ok- my paint guy wants to put Omni(warwick Blue) on my 69 gto with 3 coats of clear. He said it will be fine. Im worried about about what 75% are saying about it. How about PPG or Global with Omni clear?
EP Goat is offline
post #6 of 11 (permalink) Old 07-26-2015, 08:16 PM
Is a Flex agent a good idea?
EP Goat is offline
post #7 of 11 (permalink) Old 07-27-2015, 10:41 AM
OMNI is ok for what it does. It is a budget paint line, and like anything else, you can buy better. But if your painter is comfortable with it I don't see a problem. (I have used it before and probably will again)...
As far as the flex agent, only on the rubber stuff IMO...
mytmouz is offline
post #8 of 11 (permalink) Old 07-27-2015, 09:24 PM
Nailed it.
post #9 of 11 (permalink) Old 12-02-2015, 04:58 PM
Originally Posted by jim w View Post
has anyone used the
I use to paint motorcycles, did my share of cars as well since the early 90's
I have always used standox, I recently used restoration shop base, on my vette, standox the color I wanted was over $1000, I paid I believe just over 150.00.. for there base.. I sprayed some test panels to see the coverage, and I was impressed if you used omni, you would see a world of difference in coverage.. there is a lot more to painting than just selecting your base and top coat, but I wont get into that.. what I did was shot the restoration shop base and used my standox clear, thats the only clear I will use.. you wont go wrong with restoration base coat.. DONT GO CHEAP ON CLEAR..
ID:	68049   Click image for larger version
Name:	2014-10-25 11.48.51.jpg
ID:	68057   Click image for larger version
Name:	2014-09-18 16.07.59-1.jpg
ID:	68065   Click image for larger version
Name:	2014-09-18 16.09.55-1.jpg
66 tempest is offline
post #10 of 11 (permalink) Old 12-09-2015, 02:42 PM
Quoted: 20 Post(s)
Agreed, I shot mine in Bahama Blue Matrix Base with their premium clear (4 coats) and as a first time painter i was very happy with the results even after 4 years. I have two bubbles i need to fix this winter on hood and trunk lid just from prep not paint.
Instg8ter is offline
Trunk paint and under carriage paint.... Eshack80 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 10-28-2011 09:19 PM
paint Flyboy 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 5 12-03-2009 08:53 AM
Good Paint! (Bad Paint? part 2) Rukee 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 8 06-20-2008 09:13 AM
How's your paint ?? Cwood8656 2004-2006 GTO General Discussion 4 03-12-2007 04:35 PM
Paint Splotches+Failed Heat Gun = New Paint Job!! undertaker Service, Maintenance and Technical Discussion 3 07-07-2006 09:14 PM
