Paint back of gage cluster on 68 vert? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 11-15-2015, 07:44 PM Thread Starter
LouCabra's Avatar
I'm in the middle of replacing the dash panel on my 68. The sides and back of the gage cluster (where the printed circuit is attached) is covered in surface rust and has corroded some of the circuit. If I scrub as much of the surface rust off the metal body and protect the grounding locations (where the screws attach the circuit), can I spray the body with some kind of rust inhibiting paint? Seems like if I protect the metal where the ground straps go and the points on the circuit that it would be OK. Any advise?
Thanks!
LouCabra is offline
post #2 of 2 (permalink) Old 11-18-2015, 05:52 PM
Quoted: 16 Post(s)
When I was in the Navy I saw the Maintenance guys using this stuff called Humiseal on the Seahawks.
What I can tell you is that my hot tub had a printed circut board on the buttons that controlled the jets and what not. It has some rust on some of the connecting wires and the copper was oxidized. I used a little lemon juice on a tooth brush and took off what i could. Let it dry and then spayed this stuff all over it.
I have not opened it back up to check on the rust, but I can tell you the hot tub still works.
Maybe a clear larqur or clear paint might work. But I know 100% that this stuff does work. It is specifically designed for it.
HumiSeal 1B31 Acrylic Conformal Coating Clear - 2 can is about 26 dollars.
HumiSeal 1B31 Acrylic Conformal Coating Clear 340 mL Aerosol
tonyskala is offline
why does this stain keep coming back in splatter paint fiesta62 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 5 10-08-2014 01:42 AM
Restoring 66 GTO back to factory, need help with paint. VETKLLR 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 5 12-08-2011 09:02 AM
Will get car back from paint very soon OrbitOrange 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 05-30-2011 09:03 PM
GT500 vert versus a C6 Vert versus the Z fergyflyer Racing and Kill Forum 3 06-08-2009 08:52 AM
Bring back the Paint abodybrad 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 01-14-2009 09:17 AM
