Paint Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-12-2008, 11:42 AM Thread Starter
blondie67's Avatar
Paint Question
Hi guys! I have a paint question for you. I'm going starlight black which is paint number 9300. My body guy does not recommend this paint for it's acrylic or lacquer, I don't remember which. Anyways, he's thinking polyurethane (I think that's it. I don't know much about paint)? Which is better is your guy's opinion? I know that in vintage guitars, they used lacquer and it looks phenomenal but ages with cracks. Body guy says that I'd be mad at him if he used a single stage paint. Should I push for the stock paint?
Linda
blondie67 is offline
post #2 of 5 (permalink) Old 08-12-2008, 03:30 PM
I had mine sprayed with 3 coats of single stage as a base coat and 3 coats of clear. I don't think you will find the original lacquer paint.
05GTO is offline
post #3 of 5 (permalink) Old 08-12-2008, 04:22 PM
Quoted: 98 Post(s)
Hi Linda. the original laquers faded and checked really quickly. I had mine painted with a single stage acrylic enamel in '85 (the '65), and '93 (the '67), and they both still look good. i watched a 1968 movie last night that showed a blue '66 GTO convertible in a close up, and it needed a paint job already!! (Dull and flat). Mine are single stage, which I like. The pros recommend a two stage job: color under clear. I had a two stage job on a '66 once, show quality, and after ten years, the red paint started to fade under the clear coat, and it could not be buffed out or fixed. In hot California, I prefer the buffability of single stage paints, plus the more satin look of the finish. Back in the '60's, GTO's didn't look "wet". That being said, a black base with a clear topcoat would look great on your car, hold up better (black doesn't really fade), and up in Washington, probably last 20 plus years. I would let the painter use what he recommends and is comfortable with. You'll get a better job, and he'll stand behind his work.
Jeff
post #4 of 5 (permalink) Old 08-12-2008, 05:32 PM
Originally Posted by geeteeohguy View Post
Hi Linda.
Jeff
post #5 of 5 (permalink) Old 08-13-2008, 08:49 AM
Linda, The Urethane is the way to go. Acrylic/Urethane Lacquer is now basically illegal in NY. The new poly urethane paints actually harden better than lacquer and are much more durable.......... EA
Eric Animal is offline
Another paint problem! Please Help!!! BrazenGTO 2004-2006 GTO General Discussion 16 10-11-2008 10:56 AM
Paint Alternative GTO JUDGE 2004-2006 GTO General Discussion 10 07-19-2007 10:15 PM
Johnebgood - paint question for you 10aet2 2004-2006 GTO General Discussion 4 01-22-2006 04:25 PM
'06 Spice Red Paint Problems 10aet2 2004-2006 GTO General Discussion 10 01-19-2006 02:10 PM
A Paint By Any Other Name . . . GM Kid 2004-2006 GTO General Discussion 6 03-28-2005 03:42 PM
