paint removal from booster - Pontiac GTO Forum
post #1 of 8 (permalink) Old 08-19-2013, 08:38 PM Thread Starter
Iraq 69's Avatar
Hey Guys,
Some one gave the engine compartment of my GTO a coat of rattle can black. How do I get the black off the booster with out removing the gold color underneath?
I was afraid that paint thinner would be too harsh.
Thanks,
Marc
Marc
US Army Ret
MSG
OIF Feb 04-Jan 05
1970 GTO 455 HO
Iraq 69 is offline
post #2 of 8 (permalink) Old 08-20-2013, 12:03 AM
Yabba dab...
Test a small inconspicuous spot with a dab of acetone, and rub lightly. If that is anodized, I don't believe it'll hurt it. (Anyone?). If it's painted gold, all bets are off...
gjones is offline
post #3 of 8 (permalink) Old 08-20-2013, 08:15 PM
jmt455's Avatar
I would try paint prep solvent cleaner first, then move up to lacquer thinner if required.
I'm guessing the original plating was damaged, hence the black paint.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #4 of 8 (permalink) Old 08-20-2013, 08:37 PM
o'er spray
^^^ Or overspray...
gjones is offline
post #5 of 8 (permalink) Old 08-20-2013, 08:47 PM
I would first try a mild rubbing compound, then advance to a stronger chemical cleaner.
JMHO
05GTO is offline
post #6 of 8 (permalink) Old 08-21-2013, 06:50 PM Thread Starter
Iraq 69's Avatar
Hey All,
Thanks for the ideas. I will start with the lite stuff and work my way up. Maybe the gold won't be so bad...we'll see.
Thanks again,
Marc
Marc
US Army Ret
MSG
OIF Feb 04-Jan 05
1970 GTO 455 HO
Iraq 69 is offline
post #7 of 8 (permalink) Old 10-30-2013, 09:37 PM
Go with the acetone first, then lacquer thinner. If it's paint on the booster, match the paint and re-spray it.
Gtoman65 is offline
post #8 of 8 (permalink) Old 10-31-2013, 02:43 PM
Quoted: 98 Post(s)
I've had good luck with paint thinner on a scotchbrite pad, using gentle motion. Follow up with rags and you're good to go. I was able to clean off the overspray on the core support of my '67 that had been there for 19 years, and it left the original black paint in good shape. Be gentle and patient.
Paint removal orelog 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 1 12-15-2012 08:05 AM
'68 Brake booster...original? MO Goat 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 12-20-2011 09:24 PM
Brake Booster's Value? GTO JUDGE 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 04-27-2011 02:59 PM
Are my brakes or booster bad? MadGoat04 Drive train, suspension, alignment and brakes. 1 02-22-2010 04:17 PM
Paint Splotches+Failed Heat Gun = New Paint Job!! undertaker Service, Maintenance and Technical Discussion 3 07-07-2006 09:14 PM
