Paint Source - Pontiac GTO Forum
post #1 of 15 (permalink) Old 11-29-2010, 05:51 PM Thread Starter
Paint Source
Hi new member here. I have a 64 Tempest I want to repaint to original color which is Sunfire Red (Color Code N). Need help in finding source for paint in my area. I am trying not painting trunk and door jams this is a 20,000 mile original car.
BronaughMo is offline
post #2 of 15 (permalink) Old 11-29-2010, 07:44 PM
Quoted: 98 Post(s)
One wonders where your area is......
post #3 of 15 (permalink) Old 11-29-2010, 07:45 PM
Quoted: 98 Post(s)
Missouri???
post #4 of 15 (permalink) Old 11-29-2010, 07:52 PM
58mark's Avatar
Unless there is some reason it has to be local, I would shop at TCP global, they have paint codes going back 100 years
58mark is offline
post #5 of 15 (permalink) Old 11-29-2010, 09:54 PM
Quoted: 22 Post(s)
stopped by local (Detroit area) body shop supply place, little hole in the wall that was recommended to me by a friend whos buddy does custom paint on bikes, they can mix any custom color and put it in aerosol cans for 35.00 a pop, had never heard of that, quoted a price for BC/CC for my car (5qts) each with reducer, activator, solvent, and degreaser for around $475.00 paint is Matrix, this sound about right for a good paint? Try Painters Supply, PPG, yellow pages for body shop supplies, most have matching capabilities.
Instg8ter is online now
post #6 of 15 (permalink) Old 11-30-2010, 06:49 AM
58mark's Avatar
58mark is offline
post #7 of 15 (permalink) Old 11-30-2010, 10:19 AM Thread Starter
Sorry I should have indicated I am in Southwest Missouri. I have done some checking and know paint can be mixed useing Dupont's cheaper brand of paint and it is pretty close. We tried a scanner on inside of deck lid and it was off a bunch when test sample was mixed. I would like to find a outlet that knows their mix is pretty much dead on to original color.
post #8 of 15 (permalink) Old 11-30-2010, 10:46 AM
Quoted: 22 Post(s)
have heard same thing about Omni and some of the other cheaper blends, remember 45 year old paint even though area is not exposed to sunlight will still be slightly off new mix of original color, if your only fethering it to the edge of your doors and trunk/hood, it shouldn't be noticeable. doors (if post car) and trunk you can blend under new weather stripping, hood and inner fenders depends would probably be better to overspray with the new color or if your upper fender wrap into engine bay is good you can feather it into the inside corner. make sure you test any paint and clear over yours somewhere to make sure you dont have an adverse reaction where new blends into old. just getting ready to do my hood and trunk, jambs and interior are all done, new color is a metallic in the same blend as original so i am just overspraying them and clearing when i paint the body.
1966 Tempest pictures by instg8ter - Photobucket
post #9 of 15 (permalink) Old 11-30-2010, 10:56 AM
58mark's Avatar
I had a custom color match done at tcp once. the first time it wasn't close enough so they sent me a second attempt for free. they will keep trying until you are happy
58mark is offline
post #10 of 15 (permalink) Old 11-30-2010, 11:20 AM
66tempestGT's Avatar
are you saying the person with the scanner didnt have a formula for the original code?
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
Source of body sag? adamlcolson 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 10-16-2010 09:44 AM
Anyone know a source for verusus front bumpers?? nitrorocket 2004-2006 GTO General Discussion 0 04-15-2009 03:12 AM
Constant 12V Source? Musicmike927 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 04-06-2009 04:52 PM
Primary Source Of Music b_a_betterperson GTOforum Polls 38 02-10-2006 02:29 PM
2004 Source Awards Blacky Froman 2004-2006 GTO General Discussion 0 12-01-2004 04:37 PM
