Paint Strip on Endura Bumper - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-31-2010, 07:16 PM Thread Starter
What's the best method to strip (multiple) coats of paint from an Endura bumper? Is aircraft stripper acceptable, or will it damage the rubber? Can you use a sander? I've got a '72 with a BUNCH of paint on it. Have managed to strip most of the metal (that wasn't rusted) down to shiny metal, but not sure what to do with the bumper... Thanks for any assistance.
Dave
ID:	8221   Click image for larger version
ID:	8222   Click image for larger version
ID:	8223   Click image for larger version
stracener is offline
post #2 of 8 (permalink) Old 07-31-2010, 08:58 PM
Thumpin455's Avatar
I have been using a DA on mine, not the easiest way to do it. Really I should replace the nose on the 70, that thing is rough, so maybe I will try a few different things tomorrow and get back to you on it.
That vinyl top sure did a bunch of damage to that car, I hate those things. My 72 had one too, the pass side A pillar is almost gone. Whatever you do, dont break that rear window, those things are BIG $$$ to replace! Be extra careful with it, go price one if you really want to know.
Thumpin455 is offline
post #3 of 8 (permalink) Old 08-01-2010, 10:32 AM Thread Starter
Thanks for the tip on the front bumper. You're right, I've got to get the glass out of the car before I accidentally break any of it! The entire roof panel is completely corroded and has to be replaced. That's probably my biggest challenge in the near future. I ordered a replacement roof panel, hopefully my welding is good enough to put it back together. Time for some practice before I start...
post #4 of 8 (permalink) Old 08-02-2010, 04:54 PM
Thumpin455's Avatar
Havent tried the chem on the bumper yet, might do a bit of it tomorrow. The DA clogs up with the crappy paint thats on it right now. If yours is in better shape than mine, isnt all cracked, and has the original paint still on it, you could probably get away with scuffing it good instead of taking it all the way down to the urethane. Mine looks like a road map of Berlin on the top half, its rough and cracked bad. I should find a new one.
post #5 of 8 (permalink) Old 08-02-2010, 09:33 PM
123jboy's Avatar
The best I can remember you should not use stripper on the bumper. I just finished stripping one for a 69, sanded the whole thing down to the rubber and it turned out well. I used a cheap mouse sander from Sears. I have a link that will add some info:
http://www.goatsgarage.com/bumplft.html
123jboy is offline
post #6 of 8 (permalink) Old 08-02-2010, 09:57 PM
66tempestGT's Avatar
dont put the stripper on the rubber bumper. it will ruin it. just keep sanding.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #7 of 8 (permalink) Old 08-03-2010, 06:36 PM Thread Starter
Timely advice guys... 123jboy, the link you gave was very informative. I've got a lot of paint, and it's completely cracked and UGLY on the bumper right now. We've got a lot of sanding to do!! Thanks again for the tips.
post #8 of 8 (permalink) Old 08-05-2010, 10:27 PM
Josh.AZ.GTO's Avatar
The Goats Garage has a good tutorial on the refinishing the endura bumpers. I have two coats of paint on my 70. I plan on hand sanding with block and some elbow grease. Will take longer but in the long run I'm sure will come out much better. Definitely stay away from chemical strippers on the endura material.
Hope all goes well with roof and quarters. My first 70 GTO looked just like yours.
Josh.AZ.GTO is offline
Restoring an Endura bumper Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 10-12-2009 09:00 PM
Endura and Lemans bumper Duffman6968 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 1 01-18-2009 01:13 PM
Endura bumper restoration joker70 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 4 08-02-2008 08:34 PM
1970 endura bumper samuriskidoo 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 13 12-04-2007 01:00 PM
endura bumper gman26 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 0 07-21-2005 08:53 AM
