steering column paint - Pontiac GTO Forum
post #1 of 10 (permalink) Old 04-02-2015, 03:50 PM Thread Starter
Quoted: 14 Post(s)
On a 69 Gto with dark green interior, how much of the steering column is supposed to be painted the correct green???
greenjudge69 is offline
post #2 of 10 (permalink) Old 04-02-2015, 06:01 PM
Quoted: 106 Post(s)
The whole mast jacket up to the column support bracket.
Goat Roper is offline
post #3 of 10 (permalink) Old 04-03-2015, 04:11 PM Thread Starter
Quoted: 14 Post(s)
Thanks. Do you mean that from the column support to the floor is supposed to be black and from the column support up to the steering wheel should be green???
post #4 of 10 (permalink) Old 04-03-2015, 04:15 PM
Quoted: 106 Post(s)
Yes, here are some examples of how the columns were painted (scroll about 2/3rds of the way down).
GTO, LeMans & Tempest
post #5 of 10 (permalink) Old 04-03-2015, 04:38 PM Thread Starter
Quoted: 14 Post(s)
Great!! Thanks for your help
post #6 of 10 (permalink) Old 04-03-2015, 05:28 PM
Quoted: 106 Post(s)
You're welcome.
post #7 of 10 (permalink) Old 04-04-2015, 01:24 PM
The upper and lower bowls are the column parts that should be painted the correct shade of green on your particular column.
Only black interior cars and parchment interior cars received the fully black painted columns through '69 models. This changed for '70 models with the factory option of the Formula steering wheel. For '70 model Pontiac A-body's, if Formula wheel was factory ordered, the car came with a black steering column. things got a little crazy for '71, but nearly always, that held true for '71 model Pontiac Abodys, as well.
post #8 of 10 (permalink) Old 04-04-2015, 02:13 PM Thread Starter
Quoted: 14 Post(s)
Great. Thank you
post #9 of 10 (permalink) Old 10-12-2015, 07:22 PM Thread Starter
Quoted: 14 Post(s)
Does the steel dash top part on a 69 get semi gloss paint or flat? Also. Do the steering column bowls get semi gloss or flat paint?? Thanks
post #10 of 10 (permalink) Old 10-13-2015, 02:01 PM
the top of the dash uses a special flattening agent that gives the color a suede like finish. The upper bowls of the steering columns are closer to semigloss, but like on black for instance, am no longer a fan of semigloss Krylon 1613, it's too dull.
How do I get steering column off? smac8876 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 09-03-2013 09:17 PM
Help w/steering column Instg8ter 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 11 03-22-2012 07:19 PM
