Trunk Paint - 64 - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-16-2010, 04:35 PM Thread Starter
Trunk Paint - 64
Hi
I'm just finishing up my trunk and will be painting soon. I believe that the original color was blk/aqua spatter paint - correct? Has anyone used Zolatone? I hear that it does not have to be cleared like the rattle can stuff.
Also - I cannot find the rear taillight extension gaskets anywhere. Any suggestions - make my own?
GTOKID64 is offline
post #2 of 4 (permalink) Old 04-16-2010, 07:21 PM
daveh70's Avatar
I have a '64 too. You want to use Eastwood brand spatter finish in Black Aqua. Pt #1008Z. I also highly recommend a trunk paint topcoat after the spatter paint. Yes the car may not have originally had a semi-gloss sealant, but I think it's still nice to have.
As for the parts, I have found some things are harder to come by. Have you tried the usual suspects like OPG, Ames, Parts Place, etc?
daveh70 is offline
post #3 of 4 (permalink) Old 04-16-2010, 09:47 PM
FNG69's Avatar
WHOAA!!! If you want to be correct you will paint the trunk area the same as the exterior! You know alot of 64 is 64 ONLY. This is one of those. The 65 was finished in a gray & green spatter. You can go to page 183 in the PONTIAC GTO RESTORATION GUIDE if you want to check on this. Good Luck, Les
FNG69 is offline
post #4 of 4 (permalink) Old 04-19-2010, 07:53 PM
....that what the book says!
Eric Animal is offline
Trunk Spatter paint asshauler 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 14 09-28-2009 09:20 AM
Picking the trunk. ThomasGTO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 09-01-2008 05:29 PM
Good Paint! (Bad Paint? part 2) Rukee 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 8 06-20-2008 09:13 AM
Trunk not opening inteltom 2004-2006 GTO General Discussion 16 04-10-2007 11:14 AM
Paint Splotches+Failed Heat Gun = New Paint Job!! undertaker Service, Maintenance and Technical Discussion 3 07-07-2006 09:14 PM
