Unknown 66 Lemans Paint Code - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-19-2009, 06:58 PM Thread Starter
I am in midst of a frame-off resto of a 66 Lemans. The paint code on the name plate is "1-2". The "2" seems to be upper color of black and after stripping, the lower color appears to be bronze or gold. Problem is all the paint code charts and documentation refer only to letters, not numbers. Has anyone else seen this? Can you confirm codes? Explain why numbers vs letters?[IMG]C:\P1010358_code[/IMG]
dkp66 is offline
post #2 of 2 (permalink) Old 05-19-2009, 08:15 PM
auburnconsulting's Avatar
yeah we have 2-22. we were told it was black vinyl top and platnium paint. do you have you phs? we were also told those numbers were plant options and stamped in the wrong place. yours maybe : #1 could mean 1 of 3 things:
1 denotes your paint is standard GM paint not a Pontiac color or:
1 denotes that it is a white (ivory) convertiable top or:
1 denotes that it is a white (ivory) vinyl top
auburnconsulting is offline
1970 LeMans Trim Code 245 dljordan2 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-18-2015 06:55 AM
18" Wheel Paint Code DuaneGTO Wheels and tires 5 07-14-2009 03:17 PM
GM paint code deg04gto Exterior Discussions 3 10-30-2008 11:36 PM
GM Paint Code for 2004 Yellow Jacket? Groucho Service, Maintenance and Technical Discussion 3 10-19-2005 12:20 PM
