Where can you find Pontiac engine paint? - Pontiac GTO Forum
post #1 of 12 (permalink) Old 07-25-2008, 12:27 AM Thread Starter
70455goat's Avatar
Can't find the correct engine paint.
I have looked at AutoZone, Pep Boys, and Kragen and can't find engine paint that is correct. Kragen had one that said it was Pontiac Blue, but it was almost like a Ford Blue. Doesn't even look close. I am looking for the light blue-gray metalic looking paint that is correct for a 70.
Any ideas would be great.
Dale
70455goat is offline
post #2 of 12 (permalink) Old 07-25-2008, 07:10 AM
Check these guys. Scroll down to paint and adhesives, they show what your looking for.
The Parts Place Is The Largest Supplier Of Chevrolet Buick Oldsmobile and Pontiac Restoration Parts
post #3 of 12 (permalink) Old 07-25-2008, 10:08 AM
VettenGoat's Avatar
Check with NAPA. They stock Dupont Duplicolor, and if they don't have it in stock they can order it. Make sure you ask for the metallic blue, otherwise you may get the pre 67 eggshell blue. (For my opinion the Duplicolor is a much nicer shade than the plasticoat).
Mike
VettenGoat is offline
post #4 of 12 (permalink) Old 07-25-2008, 11:15 AM
The part number for duplicolor ceramic metalic blue is DE 1616 and this paint resist heat up to 500 degrees. I've used other paints that have burned off of the heads above the exhaust ports and duplicolor seems to hold up better.
05GTO is online now
post #5 of 12 (permalink) Old 07-25-2008, 11:53 AM Thread Starter
70455goat's Avatar
The Pontiac Blue that I found yesterday must have been the pre 67 color. I'm off to NAPA after work.
Thanks everyone.
Dale
post #6 of 12 (permalink) Old 07-25-2008, 10:49 PM
Old Indian's Avatar
Dale,
I got mine from Eastwood and it was a perfect match. I just checked the site and it appears they have changed suppliers. Hope the Napa stuff does the trick for you.
Bill
Old Indian is offline
post #7 of 12 (permalink) Old 07-26-2008, 09:47 AM
Thanks for the tip on the duplicolor Randy, I need to repaint my heads due to "exhaust port burn off"....E
Eric Animal is offline
post #8 of 12 (permalink) Old 07-27-2008, 01:08 AM
for the recod i read that mid 66 was the change time for the engen paint, early 66 and pre 66 had a light blue, late 66 and on had metallic blue, i painted the engen in my 66 metallic blue cuz it is a late modle 66, i got it at autozone, see if thay can order it for you
danthepontiacman is offline
post #9 of 12 (permalink) Old 07-27-2008, 09:45 PM Thread Starter
70455goat's Avatar
Thanks guys. I found it at NAPA. I had to go to 2 stores, but the second one had it. Now I just need to get everything cleaned up to paint it.
Dale
post #10 of 12 (permalink) Old 08-01-2008, 10:51 PM
Correc Engine Paint
Dale
Bill Hirsch has the correct paint and is very durable. Hirsch Automotive Products
I did not have any luck with Napa or Eastwood
BLS
cedar398 is offline
Pontiac tries high-performance revival Wing_Nut In the News 16 03-27-2008 07:43 PM
69 Judge-need your opinions, please joeflyer 1964-1974 Tempest, Lemans & GTO General Discussion 11 08-03-2006 12:24 AM
Worlds Fastest Production Car 05GTO The Lounge 15 11-07-2005 07:45 AM
GM's Plan To Save Pontiac And Buick 05GTO In the News 6 06-01-2005 07:52 AM
Pontiac tries to revive brand 05GTO In the News 2 02-25-2005 06:10 PM
