wire wheeling frame - Pontiac GTO Forum
 1Likes
  • 1 Post By PontiacJim
post #1 of 3 (permalink) Old 02-05-2018, 01:07 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
wire wheeling frame
Will be pulling my engine this spring and want to clean up and paint the frame in the engine compartment. I am in a rural area and don't have access to media/sandblasting equipment. I plane to wire wheel all exposed areas of the frame any tips or things to look out for would be very appreciated. Will be using a 4.5 hand grinder with wire wheel. Have see paint removal disk n a few web sites has anyone used these?
deanhickey is offline
post #2 of 3 (permalink) Old 02-05-2018, 08:15 PM
Quoted: 404 Post(s)
If wire brushing with the grinder, make sure you wear protective eye wear. Those bristles do come loose and can be shot out at you -and its always the eyes and never anywhere else.
You probably have several options to include the wire wheel. I found this, although a kit, you might do a web search for individual brushes. Looks better than the wire wheel. Abrasives - Grinding & Cutting | Discs | 3M™ Scotch-Brite™ Bristle Disc, 4-1/2 in x 5/8-11 Internal - Pkg Qty 5 | B298299 - GlobalIndustrial.com
Here is another option. I use something like this type from Walmart, ScotchBrite I think, with a drill motor that works pretty good. They clean well and I think better & faster than a wire wheel. These here are for a grinder, so probably faster than a drill: https://www.empireabrasives.com/4-1-...-removal-disc/ and YouTube:
And finally, the Flap Disc works good. https://www.homedepot.com/p/Proxxon-...yABEgI5e_D_BwE
These are all pretty good and I think better than the wire wheel. I like the ScotchBrite type discs as they are somewhat flexible and better for contours. They use up quicker than a wire wheel, but if you get better results, they are about the same in cost and less labor in my opinion. So you might want to try any of these and see what you like. None of them are all too costly. Just use eye & ear protection, and I also use a cheap dust mask so I'm not inhaling all the crap flying about in the air. Then when done, you got an excuse to have a beer to wash any residue dust from your throat.
deanhickey likes this.
post #3 of 3 (permalink) Old 02-06-2018, 02:32 PM Thread Starter
deanhickey's Avatar
Quoted: 38 Post(s)
Thanks Jim, when doing this type of work I wear goggles and a face shield. I have also found a needle attachment for my rattle gun on line., it's short money so will give it a try with the flap disks. I just hope there is good metal underneath.
Where does this wire go!!?? 06_Impulse_GTO Interior Discussions 0 11-21-2012 09:29 PM
Frame Question (Boxing frame+) Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 20 12-13-2010 12:38 PM
Tach wire ???? EVILGTO 2004-2006 GTO General Discussion 3 10-30-2010 09:45 AM
What's this wire? MichaelG 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-16-2010 11:47 AM
