This Ingenious Pass-Through Ratchet And Socket Set is 70% Off - Pontiac GTO Forum
post #1 of 1 (permalink) Old 02-04-2019, 04:20 PM Thread Starter
Your Bargain Hunter
<p class="p1">When it comes to mid-tier tools—respectable quality offerings that won't the bank like pro-grade stuff will—GearWrench is consistently a go-to brand in the pack, and we just came across one of their more out-of-the-ordinary kits at a significant discount. More commonly known for their quality ratcheting wrenches, this ratchet and socket set maintains that same mantra of streamlining your repair/DIY job.
<p class="p1">Even to the more well-versed wrencher this set might look a little confusing at first glance. Specifically designed for nuts fitted onto longer studs, as well as for bolts on top of an engine bay that have a ball socket for affixing engine covers (See right hand side of turbo coolant reservoir in this video clip), you're basically trading off a larger diameter ratchet head in order to not have to fuss with using wrenches or (if you're lucky) extra deep sockets.
<p class="p1">
<p class="p1">It's also worth noting that GearWrench added a very smart feature to the ratchet in this kit, and one you don't even always see on pro-grade ratchets out there. The flexible ratchet head in this set has a locking function, meaning you can set your desired angle and safely guide your ratchet to its target location—something that will occasionally prove frustrating without a lock, especially when using a heavier socket/extension combination. If we were looking at full-pop retail, the kit runs for nearly $200 (a bit steep, to be frank), but at 70% off you're looking at $83.30. Given the cursing and busted knuckles this kit can save you, we'd say it's worth it if you're looking to add some more specialized kit to your growing tool collection.
<p class="p1">Shop The GearWrench Pass-Through Ratchet And Socket Set Here
WiseGuide Deals is offline
  Pontiac GTO Forum > Vendors > Vendor Deals
B&M ratchet shifter? Redliner_x Interior Discussions 9 04-22-2011 02:47 PM
Signal Bulb Socket Issue? Hot_Rod 1964-1974 Tempest, Lemans & GTO General Discussion 7 03-23-2011 03:39 PM
65 ignition socket t3 bulb socket crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 11-15-2009 05:41 PM
Pass-through grommet in trunk? Gregscalade Interior Discussions 2 12-28-2006 08:11 PM
