Another paint problem! Please Help!!! - Pontiac GTO Forum
post #1 of 17 (permalink) Old 03-19-2008, 10:57 PM Thread Starter
So far, I have had my driver's side door handle replaced due to the paint peeling and I have also had documented the paint starting to bubble up at the seams at the top of the hood.
This time I have a problem with the paint on the front bumper. There was a small road chip there before but while washing it, I noticed in that area that paint started to flake off just by spraying water on it. It was about the size of a dime. I took it to the dealership about a week ago, and they said to give them a call sometime this week and let them know the day before i could come in and they would have a rental for me. I called them up yesterday letting them know that i would be in today, they had the service manager look at it. now it was the size of a nickel! i could see that the paint was still wearing away from that area. you can see on the bumper that the paint is still flaking away. they now told me that it's not covered under warranty??? the reason they gave me was that the bumper is made out of plastic and the road chip caused the paint to start wearing away.
is this right? i have never seen this before. is there a tsb over paint peeling on the front bumper? what else can i do about this?
thanks in advance!
BrazenGTO is offline
post #2 of 17 (permalink) Old 03-20-2008, 12:18 AM
Red Bearded Goat's Avatar
Sorry to read about your paint problems.... my only advise is to discuss the issue again with the stealership and logically point out the factory paint has failed in several locations (its not just localized to the bumper where the chip is located) and the chip only unmasked a larger problem with the bumper paint... that being the bumper paint did not adhere properly, same as the door handle... the proof that the paint applied or prep was flawed, is in the spider webbing on the hood... if they don't buy that argument insist you want contact info for the regional warranty claims manager to discuss it with him directly. I have several small impact chip spots on my bumper and the surrounding paint's intact. Paint only flakes away by itself if the bond was never strong enough to begin with!
Good Luck!
Red Bearded Goat is offline
post #3 of 17 (permalink) Old 03-20-2008, 08:13 AM
Funny the dealer doesn`t want to do it, they usually love to do(and get paid for) warranty work.
post #4 of 17 (permalink) Old 03-20-2008, 09:22 AM
Yikes.... Never an upside to having factory paint fail and paintwork done, regardless of who pays the bill. Sorry to hear it....
69bossnine is offline
post #5 of 17 (permalink) Old 03-20-2008, 09:35 AM
I'd cause all kind of static governing this. NO way does paint flake off over a paint chip.
I am wondering if these cars had water based paint applied to them.
My wifes 04 Grand-AM purchased at Christmas in 03, is driven every day and this includes winter driving and salt conditions. That car does not have 1 single stone chip, not a one. My GTO is in the garage and only driven in good weather and I have quite a few. My Son's Cobolt is driven every day from 2006 on and he has NO stone chips, same with my RAM since October and my 88 4Runner, you can count the chips on one hand.
The paint on these cars suck. PERIOD. I am thinking water based paint is the reason, but I am not sure if it is water based.
I just had installed a clear bra to stop the madness. Anyone know if the paint on these cars is water based?
post #6 of 17 (permalink) Old 03-20-2008, 11:24 AM Thread Starter
Thank you all for your reply's! I am trying to get information together so I can prove that this is a defect. Could I go to a different dealership for this? Is there a tsb? I would like to have some kind of paperwork to show them.
I am not sure if the paint on these cars is water based. It makes sense but I'm not sure.
post #7 of 17 (permalink) Old 03-20-2008, 12:14 PM
raspantienator's Avatar
Sorry to hear about all of your paint problems-and your car is kept like new with low miles as well.
Hope the dealer re-paints it for you.
raspantienator is offline
post #8 of 17 (permalink) Old 03-20-2008, 09:34 PM
speedwrenchx10's Avatar
I had my rear facia replaced due to paint flaking/falling off.I wonder if the monaro nose chips easy or paint issues with the rear facias?Were the GTOs monaros then convered to the GTO after off the assembly line?Were the GTO parts painted separate then installed after monaro parts were removed?The result poorly preped and painted pieces.My local stealership has lifetime warranty on everthing the paint so when I need paint its all them.
speedwrenchx10 is offline
post #9 of 17 (permalink) Old 03-21-2008, 10:26 AM
That's a really good point. The GTO front and rear fascias most likely were done "off-line" from Monaro production. And considering that building fixtures, and calibrating/programming the process for running body parts through robotic paint lines and the downstream factory ovens is HUGELY expensive to set up (and then would have to be switched back and forth between Monaro & GTO which would be wholly unfeasible), the GTO bits were likely done the old-fashioned way, by humans.... flawed and inconsistent humans.... And the tendency to chip easily could be attributed to poorer curing/baking techniques/equipment off-line, combined with inconsistant and/or lazy prep-work.
It's all making sense to me now...
post #10 of 17 (permalink) Old 03-21-2008, 01:55 PM
formerly NJGoat
NJG8GT's Avatar
My rear fasica was just replaced last week. Then had to purchase more letter inserts for the GTO cut outs. They told me paint adhesion problem.
2009 Pontiac G8 GT Liquid Red, sport & premium pkg, Lloyd floor mats, Pontiac trunk liner, mobil 1 plus Z-Max, VG sharkfin antenna, Volant CAI, Superchips Cortex 93 octane Volant tune, Solo -Performance axle-back exhaust, Solo X pipe, BP-catchcan
NJG8GT is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Paint Alternative GTO JUDGE 2004-2006 GTO General Discussion 10 07-19-2007 11:15 PM
Paint Chipping kevlar2005 Exterior Discussions 8 03-04-2006 09:32 AM
Johnebgood - paint question for you 10aet2 2004-2006 GTO General Discussion 4 01-22-2006 05:25 PM
'06 Spice Red Paint Problems 10aet2 2004-2006 GTO General Discussion 10 01-19-2006 03:10 PM
GTO Automatic Shift Problem smckullie Service, Maintenance and Technical Discussion 5 02-23-2005 07:02 AM
