Cold air intakes - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-15-2019, 11:33 PM Thread Starter
Seeking options on a cai to purchase, not really sure what my options are for my 2005 gto.
Noishh1 is offline
post #2 of 4 (permalink) Old 04-17-2019, 11:45 AM
nardulli's Avatar
Send a message via Skype™ to nardulli
Hey - happy to help.
The problem with most CAI setups is that they don't work. For instance, the K&N setup mounts the air box in the same location as the OE box. That requires a long plastic intake tube to mate up with the Throttle Body. That tube becomes heat soaked. Cold air not so much. Yu can get the same bang for your buck by putting in a K&N filter in your stock air box. Promise. We tested this on a dyno. The one filter setup that seems to work is the Vara Ram kit. See the photo below. This shows my car (before current mods) with the vara ram installed. Bonus is that this leaves the place on the fender well available for a remote dual oil filter setup. (Bypass plus full flow). Downside is that the vara ram setup includes a cheesy plastic shroud and the filter will rub slightly on the insulation under the hood. Probably a lot of guys on here will call BS on my post but the dyno doesn't lie.
nardulli is offline
post #3 of 4 (permalink) Old 04-18-2019, 12:58 AM Thread Starter
How was the installation with the Vararam intake?
Noishh1 is offline
post #4 of 4 (permalink) Old 04-28-2019, 11:54 AM
nardulli's Avatar
The install is really pretty simple. Get the vararam filter setup plus the wedge that changes the entry angle of the throttle body. This is the most gain I saw per dollar spent. You will need to trim the OE fan shroud across its top. I used a Dremel angle saw. The wedge also helps with the hood liner problem.
nardulli is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
75 Trans Am 455 - open air element, dual snorkel or cold air intake? bnreed3 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 07-08-2016 05:48 PM
cold air intakes? gto4life Intake and Exhaust Discussions 3 06-22-2009 10:06 PM
Cold Engine + Cold Tires = Runs like crap! Russ2005 Service, Maintenance and Technical Discussion 14 12-31-2005 12:54 PM
New Era Intakes On Sale!! GTODEALER Service, Maintenance and Technical Discussion 1 04-26-2005 06:00 PM
