Hood struts - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-16-2019, 08:10 PM Thread Starter
Hood struts
Does anyone know what the pressures are on the factory hood struts? I need to get lower pressured ones now that I have a custom fiberglass hood
sstank is offline
post #2 of 4 (permalink) Old 08-17-2019, 08:05 AM
AlaGreyGoat's Avatar
https://www.liftsupportsdepot.com/st...-lift-support/
Larry
AlaGreyGoat is offline
post #3 of 4 (permalink) Old 08-17-2019, 09:17 AM
Stephen Blakeney's Avatar
Quoted: 4 Post(s)
Those are stock struts. Now all you have to do is take the specifications from that chart and find struts the are the same except for the "Force (Lbs)" spec. Problem would be determining how much less that needs to be based on the difference in the weight between a stock hood and your "custom" fiberglass hood and finding struts with those specs. Good luck.
Stephen Blakeney is offline
post #4 of 4 (permalink) Old 08-17-2019, 04:27 PM Thread Starter
Thanks so much for the information. I think I will just call this manufacturer and see if they have lower compression struts.
sstank is offline
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
