Little more horse - Pontiac GTO Forum
post #1 of 10 (permalink) Old 04-21-2019, 08:25 PM Thread Starter
Little more horse
What is a good mods for horse power gain but not to pricey to start with
Todd Crain is offline
post #2 of 10 (permalink) Old 04-25-2019, 07:41 AM
Not much that isn't pricey. Speed is money. Start with long tube headers. $1000
SB71 is offline
post #3 of 10 (permalink) Old 04-25-2019, 09:41 AM
Quoted: 9 Post(s)
Then heads, then CAI, and then STOP!!! Trust me. It's a bottomless hole trying to go faster.
tiretread is offline
post #4 of 10 (permalink) Old 04-25-2019, 07:39 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
The best $25 dollars you can spend and see it is to curve your distributor, a curve kit about $12,..the correct vacumn advance can about $13.
You will feel it through all Rpm ranges, and most are set up wrong..
Next would be to get your AFR correct....not too rich, not too lean...just right for cruise and power
Lemans guy is online now
post #5 of 10 (permalink) Old 04-25-2019, 11:01 PM
GTO44's Avatar
Quoted: 37 Post(s)
Unfortunately LS motors don’t have distributors lol
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #6 of 10 (permalink) Old 04-25-2019, 11:04 PM
GTO44's Avatar
Quoted: 37 Post(s)
If auto best mods are toque converter, headers and a tune. If stick a 3.91 gear, headers and a tune. Unfortunately none of these mods are “cheap”. The late model gto is not a cheap platform for upgrading.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is offline
post #7 of 10 (permalink) Old 04-26-2019, 02:35 AM
AlaGreyGoat's Avatar
Horsepower = money$$$
I was lucky to get a new/used Vortec blower kit from A&A and installed myself on my 04 Z06. Really, much easier than
expected. Would be even easier on the GTO. After getting it tuned, it ran just under $4k. Picked up a safe 170rwhp.
Headers are the only needed accessory for a small blower/turbo kit. Gets around 22mpg tooling around, also.
You will also need a good supply of cash for rear tires.
Larry
AlaGreyGoat is online now
post #8 of 10 (permalink) Old 04-26-2019, 03:11 AM
Also, for a deal on coated Pacesetter #72C2258 Headers $329.58 free shipping:
https://www.ebay.com/itm/Pacesetter-...cAAOSwowdciuiw
I installed a set of these non-coated in June, 2007 at 53,289 miles. About 8 months ago, at about 206,000 miles, I had a small rust
hole over the #7 tube at the flange. I put a small piece of header wrap under a hose clamp and still going strong. I bought a set of
these (were $358.03 then) and will install when I feel like it. Dropping the steering rack down isn't any fun.
These are not stainless steel, but they are not a thousand dollars, either.
My uncoated headers cost $285.97 in 2007 and I got 12 years and 153,000 miles before any problems.
Larry
post #9 of 10 (permalink) Old 04-26-2019, 06:46 PM
Lemans guy's Avatar
Quoted: 54 Post(s)
Spot on GTO44!????those LS motors are awful good, now if you have the earlier version that have PCV valve..I would suggest as a lower cost upgrade an ME Wagner dual flow PCV Valve.
That valve I run on my 460 Pontiac, and it will do a lot of nice things for your engine. First it will pull a vacumn in the crankcase of 1 to 3 hg 99% of the time and you tune for your motor, on the motor. Second it will pull out all of that blow by crud and condensation and some car ones up oil.
Best is to run it with a catch can and then your PCV feed into the intake is also all cleaned up, better for your mixture, cleaner for your intake, your valves and your cylinders. Will leave lots of less carbon gunk.
In addition it will allow the downstroke of the piston to be pushing against a slight vacumn rather than a slight pressure, a possible small horsepower gain. It will also stop annoying leaks from seals and gaskets and oil out the breather.
Your current cheap $6 PCV valve will only pull a vacumn 10 to 30 % of the time. See the tests on ME Wagners website.
So all of that, with work you can do yourself and you donít have to have major engine changes or even crawl underneath it.
Cost the Wagner dual flow is $129, catch cans run from $20 to a few hundred. Get one with a dipstick or a sight glass. I use a Radium Catch.
can.
Make sure your ME Wagner vale is baffled so you donít lose too much oil.
So $140 to $500,....Cleaner, more power, less leaks, better AFR mixture you can do it yourself.....that is a good upgrade even on an LS motor.
Then buy you a bottle of Redline S1 fuel system cleaner and put it in your tank, and use it per directions, cleans valves cylinders and keeps intake and carb clean....
It has the only real cleaner for high temp carbon deposits, PEA....which is Techron invented by Chevron Chemists and used in their gasoline.
Now donít you feel better? ....Even though you are missing a distributor!
post #10 of 10 (permalink) Old 07-30-2019, 09:56 AM
Could also do a cam. Good amount of work, but isn’t too pricey depending on how mechanically inclined you are.
Scott70 is online now
  Pontiac GTO Forum > The 2004-2006 GTO > 2004-2006 GTO General Discussion
Horse Power Issue STSGTO Engine Discussions 3 12-11-2012 08:40 PM
Horse Power Ratings for 1967 GTO "Standard" 335 HP 400 3rd1967gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-28-2011 07:28 AM
Horse Increase? GTO'n'TRANSAM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 02-02-2009 08:01 PM
Horse power gain for "loudmouth" exhaust? FULLTHROTTLE Service, Maintenance and Technical Discussion 0 03-08-2005 11:30 AM
pontiac claims 350 horse i read actual is 290 BLUSHIRT35 Service, Maintenance and Technical Discussion 11 09-22-2004 05:47 PM
