04 GTO Radiator Fan Issue - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-21-2014, 10:52 AM Thread Starter
Kept hearing a rattling noise coming from the front of the car when the fan kicks on, and I finally got around to looking today. Seems one of the fans has a lot of play in it. Could it be the motor bearing going out or is there any other way to tighten it up? It's pretty annoying hearing it rattle while I'm idling in traffic.
DR3DD is offline
post #2 of 2 (permalink) Old 10-21-2014, 11:36 AM
Pull it out and look at it. It's really easy to remove. After taking off the obvious unplug the fans. There are two tabs you push down, one on each side, and pull the fan assembly up. The hoses get in the way but I was able to bend them out of the way enough to slide the fan assem. out.
1965 GTO 389: big radiator - fan shroud too small torpedo51 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 12-08-2017 08:18 AM
65 gto radiator fan jsmaem1106 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-18-2013 05:35 PM
Clearance between Radiator Fan shroud and fan jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-22-2012 04:51 PM
06 GTO 6.0 radiator issue RedRun06 2004-2006 GTO General Discussion 1 06-08-2011 03:55 PM
