04 GTO-Turns over but then dies - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-29-2018, 10:07 AM Thread Starter
I have a 2004, automatic. The car turns over, runs a few seconds and then dies. There is no check engine light coming on. Thoughts on what it can be?
NU GTO is offline
post #2 of 2 (permalink) Old 10-06-2018, 02:38 PM
GTO44's Avatar
Quoted: 37 Post(s)
You're BCM is malfunctioning. I had the same problem about 5 years ago. Car would start, run a few seconds and shut off. GM ended up replacing the bcm under factory power train warranty.
Since the power train warranty is no longer active you will have to pay GM $1000 for a new BCM and $400 to program it. Or do like i did last month when my BCM died again....
Take ur BCM out (under passenerside dash after u remove glove box). Go to www.G7computers.com . Send them $225. Fill out the tech card, put it in a box with the bcm, and ship it to they're address. The GARUNTEE they will fix it and send it back in the mail the same day or they send u ur money back. Its the best solution out there right now. My gto sat for the last 3 months (when my bcm died again)while i was trying to find someone to clone my bcm onto a used one.... then i found that site. Its a life saver and way cheaper then new parts from gm.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
06 gto turns over will not start xfasteddiex Service, Maintenance and Technical Discussion 0 03-12-2017 12:53 PM
70 GTO & Holley carb dies around turns or braking michaelrj9 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 02-08-2016 06:14 PM
P0335, TCS turns off, and crank/no start or start then die. dlb1982 Service, Maintenance and Technical Discussion 2 10-13-2015 09:57 PM
1970 GTO dies when braking and around turns michaelrj9 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 09-15-2014 08:16 AM
1970 400 dies around turns michaelrj9 1964-1974 Tempest, Lemans & GTO General Discussion 4 07-23-2013 09:36 PM
