04 m6 Alternator Charging Issues... - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-20-2014, 05:58 AM Thread Starter
Okay so to start it off I'm on my number 5 or 6 re manufactured alternator in under two years. Most recently they seem to be lasting approximately one week (last two anyway). I will install them and they will work perfectly charging at 13.9-14.1 volts then all of the sudden out of no where I will get check alternator light and battery starts to slowly drain. Battery is relatively new and when I put my multimeter on the posts after issues start to occur I get anywhere from 11.7 to 12.1v showing that the alternator is putting out nothing. I have checked the wiring as best I can under the hood, the battery terminals are not corroded and I'm getting so frustrated that I'm almost ready to trade the car off which I do NOT want to do. Does anyone have any suggestions or ideas or has maybe ran into this problem and has found a fix. Please help
stephen77375 is offline
post #2 of 2 (permalink) Old 05-20-2014, 11:52 AM
teds06goat's Avatar
I would try checking all the grounds and stay away from the re manufacturer alternators. And you can try switching out the battery cables.
Sent from AutoGuide.com App
teds06goat is offline
Charging System issues Thurber73 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 02-28-2014 08:04 PM
Alternater not charging xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 08-06-2010 04:21 PM
Charging Problem e_zrider 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 05-21-2010 11:28 AM
charging system mafiacustomz 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-16-2009 12:01 PM
charging problem? PhantomGTO Service, Maintenance and Technical Discussion 5 07-11-2005 09:40 AM
