'04 M6 Shifter Rattle - Pontiac GTO Forum
post #1 of 6 (permalink) Old 03-06-2006, 04:57 PM Thread Starter
Anyone have shifter rattle during anytype of acceleration in you M6 GTO?
BlownGTO is offline
post #2 of 6 (permalink) Old 03-06-2006, 05:41 PM
b_a_betterperson's Avatar
The shift knob has been known to cause a rattling sound because of its design. It's pressure fit to the shaft instead of threaded. Just pull the knob off and run a piece of electrical tape up one side of the shaft, over the top, and down the other. Press the knob tightly into place -- and you'll be all set. I did this when installing my B&M -- and it has worked like a charm. Can't remember if you have to pull the console cover or not. Either way, it's a simple and effective fix.
b_a_betterperson is offline
post #3 of 6 (permalink) Old 03-06-2006, 06:01 PM
You will need to pop the console cover off, as the knob and boot come off as a single assy.
The rattle is very common, and very annoying. I haven't gotten arounf to fixing the damned thing yet, but will soon make the time.
Groucho is offline
post #4 of 6 (permalink) Old 03-06-2006, 06:25 PM Thread Starter
Thanks guys, WTY should cover this but since its so easy i might just do it myself.
BlownGTO is offline
post #5 of 6 (permalink) Old 03-06-2006, 08:53 PM
Holden's Avatar
Does it go away after car warms up? Thats what mine does, I think its Engin vibration. I know knob not loose I used epoxy on it. Mine is worse after sitting a fiew days If I drive daily goes away prety fast. I have 4K mi and Royal Purple in Trany.
Holden is offline
post #6 of 6 (permalink) Old 03-07-2006, 11:52 AM Thread Starter
Mine is always there, warm or cold, hard or soft accel.
BlownGTO is offline
