05 GTO AT4 and trans cooler question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-18-2017, 01:14 AM Thread Starter
R3V
so i have a 2005 GTO AT4 (all stock) and i looking to get a trans cooler. i dont really know which one to get, i wanted to get some opinions from people who have one. which one would still be good with future power upgrades (if i ever do any), should i bypass raditor or not (i think i shouldnt but still want some input from people), and what would be the best btu rating for my applaction . also i live in colorado where winter can get pretty cold and summer can get pretty hot and i dont know how the winter can effect the performance of a trans cooler. oh and side question if i install a trans fluid temp sensor should it be on the pan or inline with the hoses coming off of the transmission but before the coolers
R3V is offline
post #2 of 3 (permalink) Old 01-18-2017, 11:32 AM
GTO44's Avatar
Quoted: 37 Post(s)
Go with the B&M 24k GVW cooler. It's on Maryland Speed:
B&M Supercooler Transmission Cooler 14,400 BTU/24,000 GVW [70264] - $129.95$89.95 : MarylandSpeed.com- Your First Stop on the Way to Performance!
And here's everything you need to know about parts and install.
B&M Transmission Cooler Install - Simple Questions - LS1GTO.com Forums
There are multiple threads referenced in there that should help you with the install and also the parts you would need if you want to convert to -6AN lines.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is offline
post #3 of 3 (permalink) Old 01-18-2017, 11:13 PM Thread Starter
R3V
Thank you for the info and links
R3V is offline
66 Lemans trans cooler lines Lemans guy 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-15-2014 07:23 PM
Trans cooler lowpro192000 Drive train, suspension, alignment and brakes. 0 06-26-2011 10:37 PM
A4 trans cooler bridogr1 2004-2006 GTO General Discussion 1 06-26-2011 02:00 PM
Trans cooler lines teamwoody72 1964-1974 Tempest, Lemans & GTO General Discussion 6 05-03-2009 06:37 AM
Trans cooler question 04 Goatman Service, Maintenance and Technical Discussion 0 09-22-2007 03:21 PM
