05 GTO Drive Shaft Problem - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-29-2014, 05:19 PM Thread Starter
Fellas,
My GTO has recently been making some grinding noises due to the drive shaft bearing getting wore and loosening. My question is 1. Is there a way to replace the bearing instead of the whole drive shaft? 2. If so, where would/could I find it?
Nick
nl18145 is offline
post #2 of 2 (permalink) Old 09-29-2014, 08:29 PM
There have been some people that have done it although GM does not sell that part. The other problem is the guibos on either end are rubber and also wear. By the time you rebuild it you could have gotten a one piece.
Drive Shaft funbooker 1964-1974 Tempest, Lemans & GTO General Discussion 4 10-24-2013 07:14 PM
drive shaft? hemi1282 Service, Maintenance and Technical Discussion 6 10-21-2013 08:11 AM
Drive Shaft Stamp235 Drive train, suspension, alignment and brakes. 5 07-29-2007 01:43 PM
