05 GTO with evap code po466 & white smoke plz help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-18-2015, 05:22 AM Thread Starter
Bobcat911's Avatar
Hookayy so my 2005 goat has approx 45,000 miles and threw the dang evap P0466 code ONLY ..and I noticed white smoke from the right tailpipe...but not the left. Smells a little lean or gas like ...harder it runs=more smoke. Oil looks good in texture and color, and coolant is in the resovior....not running hot.
Plz advise if u can I surely appreciate it...
Jen
Bobcat911 is offline
post #2 of 3 (permalink) Old 10-18-2015, 01:10 PM
Evaporator solenoid circuit. That solenoid is up by the TB on the driver's side of the intake manifold. It could be as simple as the gas cap though. First make sure it isn't damaged where it seals and then make sure it is fully on. Clear the code by pulling the Neg. battery terminal for a few minutes and then after reconnecting see if the light is out and drive it to see if it comes back on.
As to your differences in exhaust the evap circuit would not affect one side more than another so there may be two different issues.
post #3 of 3 (permalink) Old 10-18-2015, 01:18 PM
If that doesn't work Konnie wrote it once so why write it again. . .
Evap system testing
white smoke Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 8 01-31-2012 12:02 PM
looking for dupont paint code for m37 white interior freethinker 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 0 05-31-2011 11:48 AM
White Smoke in Exhaust! Argh! noahtodras 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 10 05-13-2011 05:31 PM
White smoke from left pipe only spencer70 Intake and Exhaust Discussions 8 05-12-2011 02:28 PM
