05 gto who my car have any problems if the overflow tank was removed? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-21-2013, 08:28 AM Thread Starter
having problems with the clearance with overflow tank
tavarismickens is offline
post #2 of 7 (permalink) Old 03-21-2013, 10:12 AM
Are you talking coolant overflow tank? Is it an original tank? Car been in an acident?
post #3 of 7 (permalink) Old 03-21-2013, 06:23 PM
Trying to put an air intake in the area or something? You need to have some sort of tank but there are aftermarket ones and they can be relocated.
post #4 of 7 (permalink) Old 03-27-2013, 02:08 PM
danfigg's Avatar
re
eventually yes, the car will loose coolant. Thats what the over flow tank is for it captures what get forced out under pressure and then gets sucked back in as the car cools down. If you take the tank off, you will have to plug the over flow hose and I dont know how much pressure your cooling system will be under and how much it can take...danfigg
05 IBM M6 summit UDP Vararam OVRAI Dyno tech long tubes W 04/catted mids 04 spintech X-pipe merged into 05 kooks after burners In-tune diablo tuner
danfigg is offline
post #5 of 7 (permalink) Old 03-27-2013, 02:55 PM
No, don't plug it, you will over pressurize the system. Leaving the tank off will force excess coolant out the overflow tube when hot, but it won't have any to replace that coolant when cooled, so your radiator will always be an inch or two low when cold.
post #6 of 7 (permalink) Old 03-27-2013, 08:21 PM
danfigg's Avatar
re
I should of just said "NO"...You cant remove the tank---danfigg
danfigg is offline
post #7 of 7 (permalink) Old 03-28-2013, 03:18 PM
Sure you can remove it. I replaced mine with a "catch can" that is attached to the PS shock tower. Line goes from radiator overflow to the bottom of the catch can. Then hose from top of "catch can" run out of engine bay. Acts just like factory but adds a route to release excess coolant if needed.
grifter95 is offline
Pontiac 05 GTO overflow tank tavarismickens 2004-2006 GTO General Discussion 3 03-25-2013 11:06 PM
1969 gto gas tank problems harp 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 09-04-2009 05:41 AM
1968 gto overflow question abodybrad 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-29-2009 09:10 PM
My car gets 10,000 miles on a tank of gas?!?!? mlyon Interior Discussions 7 06-27-2007 08:37 AM
Unsolved Coolant Leak from overflow tank... Striker222 2004-2006 GTO General Discussion 5 08-20-2006 05:45 PM
