05 hood rubber inserts - Pontiac GTO Forum
post #1 of 13 (permalink) Old 02-14-2006, 05:32 PM Thread Starter
so the rubber inserts when u pop the hood that go in the hood scoop well can be popped out, is there any downside to doing this, i know i wont really see any performance gains but maybe it will keep the engine a little cooler.
DK2F is offline
post #2 of 13 (permalink) Old 02-14-2006, 05:39 PM
fergyflyer's Avatar
Keeping the engine cooler will produce performance gains. I removed my fuel rail covers and hood plugs at the drag strip and did some playing around. The car cools a lot quicker between runs without the plugs and fuel rail covers. In the summer I also noticed a difference of 1-2 tenths due the engine not heating up as much in the staging lanes and during staging.
fergyflyer is offline
post #3 of 13 (permalink) Old 02-14-2006, 05:59 PM Thread Starter
is that what there called, hood plugs, i didnt think itd be enuff cool air to produce any real gains, im talking about the rubber pieces inside of the hood scoops that u can pull out? is that what u were reffering to?
DK2F is offline
post #4 of 13 (permalink) Old 02-14-2006, 06:31 PM
raven1124's Avatar
Send a message via Yahoo to raven1124
That is what ferg was referring about. I took mine out and only put them in when it's raining and when I was it. As far as performance, maybe a little. The more air you have running through your scoops the better to keep your motor cooler.
raven1124 is offline
post #5 of 13 (permalink) Old 02-14-2006, 09:40 PM
s2gordon's Avatar
I took mine out and the motor does seem to cool down a bit better. I've left them out in a few of our FL rain storms and nothing's happend. However i've noticed more dust building up in the enginge area with them out. I'm having to wipe it down twice a week now.
s2gordon is offline
post #6 of 13 (permalink) Old 02-14-2006, 10:10 PM
fergyflyer's Avatar
Same thing happened here as far as dust, dirt and bugs on the engine. I never put mine back once I took them out. The fuel rail covers protected the coil packs though so the only time I took those off was when I was at the track.
post #7 of 13 (permalink) Old 02-14-2006, 10:16 PM
raven1124's Avatar
I've haven't noticed any dust(now you are making me paranoid) but I forgot to put them in one time when it was raining and the motor was pretty wet.
post #8 of 13 (permalink) Old 02-14-2006, 11:36 PM
maybe put some mesh or some little crappy filters in place of those rubber baffles? Might cut down on that dust buildup and keep water out.
CrabhartLSX is offline
post #9 of 13 (permalink) Old 02-15-2006, 12:24 AM
raven1124's Avatar
I was thinking around those same lines. Maybe over lap the existing screen with some type of mesh screen. Definitely would help out with bugs but I doubt it would help with the water issue.
post #10 of 13 (permalink) Old 02-15-2006, 08:47 AM
GM Kid's Avatar
When I'm at speed--say, 80 or so on a freeway--I've noticed that the hood shimmies a bit. Just keep an eye on the panel gap between the driver's side front fender and the hood and see if you don't notice it, too.
I have a notion that whatever air is getting through the hood scoops (I've left the rubber inserts in place) is causing a bit of lift under the hood, making it vibrate a bit. I'd be curious to know if '04s do the same thing, or if their hoods sit still.
Anyway, I'd imagine that taking the inserts out would only increase this phenomenon in steady-state cruising at speed.
GM Kid is offline
