06 Goat W/ Radiator Crack. 45kmiles - Pontiac GTO Forum
post #1 of 16 (permalink) Old 10-15-2010, 01:28 PM Thread Starter
06SixOhGoat's Avatar
Well i looked outside and saw a puddle. Yup radiator is cracked. AWESOME!
Uploaded with ImageShack.us
Tony Smith
2006 M6 Torrid Red/Red Interior
Intake and Resonator and Muffler Delete.
!!!COMEING SOON ON WAITING LIST AT SHOP!!!
Ported Intake Mani and Trottle Body and Street Tune
06SixOhGoat is offline
post #2 of 16 (permalink) Old 10-15-2010, 02:02 PM
jpalamar's Avatar
I can't see the pics since I'm at work. Where is the crack... is it the core or the side tanks that crack or the crimps the connect the sidetank to the core?
I did my rad last year and it wasn't to bad to do so let me know if you need help(it takes 2 sets of hands).
And def get a new t-stat in there since they are only $15 or so.
jpalamar is offline
post #3 of 16 (permalink) Old 10-15-2010, 02:39 PM
GM4life's Avatar
JBWeld and call it a day.
GM4life is offline
post #4 of 16 (permalink) Old 10-15-2010, 03:43 PM Thread Starter
haha JB-Weld yeah right. Its under warrenty still so hopfully its goign to be takin care of. i was thinking of ordring the 160 degree from SLP after i got the car back.
Tony Smith
post #5 of 16 (permalink) Old 10-15-2010, 03:51 PM Thread Starter
Jason im not sure were to explain exactly were the crack is. its in the plastic on the front side of the radiator on the batt side. theres like a 3" tap sorta were the tranny radiator is at. its cracked all done the side of that. Tow company is on the way. gotta tow it 40miles ef my life. but warrenty takescare of it. only got a 100 deductable. not 2 bad cuz my rear seal is leaking too lol.
Tony Smith
post #6 of 16 (permalink) Old 10-15-2010, 11:21 PM
GM4life's Avatar
Ok then, duct tape and bubble gum..Wow, cheaper than the $100 dedutable
Looks like you got the extended warranty? That helps, expecially when common things for this car is overpriced.
160 degree is fine but works better if the fan temps are adjusted too.
GM4life is offline
post #7 of 16 (permalink) Old 10-16-2010, 04:29 PM Thread Starter
yeah so heres what im getting replaced for 100 bucks. Radiator, Rear seal, and wiper switch.
Tony Smith
post #8 of 16 (permalink) Old 10-16-2010, 04:30 PM Thread Starter
how do i adjust that. is that adjusted by getting a tune or programer only?
Tony Smith
post #9 of 16 (permalink) Old 10-18-2010, 07:53 AM
jpalamar's Avatar
Tune can adjust when the fans, I belive the handhelds can as well.
Also be careful with the 160* t-stat, we are far enough north that it will most likely through a CEL for not hitting operating temps in the winter. When my stock t-stat failed(got stuck partially open) my temp wouldn't go all the way to normal unless I was in bumper to bumper traffic. At highway speeds I would CEL everytime. I replaced it with a stocker.
jpalamar is offline
post #10 of 16 (permalink) Old 10-18-2010, 01:07 PM
GM4life's Avatar
Good deal.
Yes its adjusted by a tune or programmer. If I remember correctly the 05-06 is adusted by percentage not by temperature.
GM4life is offline
Radiator PisnNapalm 1964-1974 Tempest, Lemans & GTO General Discussion 20 08-04-2012 08:15 PM
Radiator Dimension for 05 goat NC_Shogun Service, Maintenance and Technical Discussion 0 03-12-2009 03:58 PM
Need Radiator? btchplz Engine Discussions 11 02-21-2009 02:33 PM
crack monkey crack monkey Member Introductions 2 06-23-2007 01:34 PM
California to crack down on modified cars fergyflyer Service, Maintenance and Technical Discussion 18 08-07-2005 04:34 PM
