06 Gto high rpm power - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-22-2016, 11:03 PM Thread Starter
Just got an 06 gto m6 vararam cai, and exhaust dont know if it is tuned. but it has no power at high rpm its like it red lines at 5k it just floats there. then i will shift it does alright untill i gets back up into the 4k range. no codes please help
06silverGoaTO is offline
post #2 of 4 (permalink) Old 05-23-2016, 07:53 AM
That's very strange indeed. First thing that comes to mind is clogged exhaust, maybe bad cats?
:edit If it was the exhaust you should be able to loosen the pipes at the manifolds and take it for a quick test drive to see if it revs higher.
post #3 of 4 (permalink) Old 05-23-2016, 12:55 PM
Valve springs? Almost sounds like valve float
post #4 of 4 (permalink) Old 05-23-2016, 08:06 PM Thread Starter
i was thinking the route of the valve springs cause it does have a slight knock. changed the oil today it was clean no metal shavings or anything. the car is runing real rich and i just ordered pacesetter headers, off road mid pipes and slp lm1. so maybe that will change somthing.
High RPM Misfire kilkm68 Engine Tuning 4 04-10-2013 07:26 AM
06 gto losing high rpm power FATASSGOAT Service, Maintenance and Technical Discussion 8 03-19-2012 10:01 AM
1970 GTO: Why are RPM so high when speed is low? TheBestVMan 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 22 02-29-2012 01:06 PM
Vibration at high rpm 66tripower 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-10-2011 07:52 PM
high rpm vibration 66tripower 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 08-10-2011 10:13 AM
