06 gto misfire - Pontiac GTO Forum
post #1 of 10 (permalink) Old 12-17-2010, 06:01 PM Thread Starter
06 gto misfire
i have an 06 gto with 60,000 miles. cylinder 6 misfires the most and 4 just somtimes. ive replaced plugs, wires, and coils and still the same thing please help with any ideas on what it could be thanks
s10ss is offline
post #2 of 10 (permalink) Old 12-17-2010, 07:25 PM
06BLACKGTO64's Avatar
Send a message via Yahoo to 06BLACKGTO64 Send a message via Skype™ to 06BLACKGTO64
have you checked the fuel injectors? something you could do is change an injector from another cylinder and see if the problem jumps.
06BLACKGTO64 is offline
post #3 of 10 (permalink) Old 12-17-2010, 11:47 PM
87GN06GTO07IRL's Avatar
Do a fuel pressure test and a compression test too.
87GN06GTO07IRL is offline
post #4 of 10 (permalink) Old 12-28-2010, 10:32 PM
JRSGTO's Avatar
my brother works at an Audi dealership as a service advisor and for the past couple of weeks customers have been saying that there cars are 'misfiring' or something like that.....he said that high octane fuel like 93 gets affected by the cold weather..has something to do with the Volatility, cant remember the science behind it... but putting 87 octane when its cold fixes the problem...weird i know but if this is a new thing ur goat starting doing when it got cold, i would give 87 octane a try, but just maybe a half tank...if it has nothing to do with the cold then now you know something new
JRSGTO is offline
post #5 of 10 (permalink) Old 12-29-2010, 02:43 PM
so, did you do the 87? what was the outcome
lingenfelter cai, vararam tb spacer, v/max ported tb, livernoise stage 2 heads with comp cam 232/232/.50 114 lsa. slp 1 3/4 headers high flow cats, x pipe, qtp cut outs, flowmaster mufflers. tuned by tt performance , highly recomended in n.j.
NEXSTAR7 is offline
post #6 of 10 (permalink) Old 12-29-2010, 02:45 PM
jpalamar's Avatar
That 87 thing doesn't sound legit.
jpalamar is offline
post #7 of 10 (permalink) Old 12-30-2010, 05:01 AM
Ive heard of fuel causing an engine to run poor..when i worked at ford we had a bunch of vehicles come in with failing injectors and we took a rough survey and most of the used BP regularly, we summed it down to BP using different additives in their fuel but nothing was ever proven. if it was a fuel thing though i dont think it would call out the same cylinder just about everytime and only between two cylinders..I would stick to checking Fuel pressure, changing the injector from that cylinder with a cylinder that is not called out and if none of those work i would start looking at the coil pack to see if your getting proper spark. fuel thing seems like a longshot IMHO
post #8 of 10 (permalink) Old 12-31-2010, 05:07 PM
taylorb765's Avatar
He figured out the problem it was a melted down converter, i know this because i sold him the car.
2006 GTO Edelbrock shorty headers, x pipe, muffler deletes, K&N airbox, diablosport 91 octane tune, billet short throw shifter.
1.90 60ft, 8.46 1/8, [email protected] 1/4
taylorb765 is offline
post #9 of 10 (permalink) Old 01-01-2011, 08:10 AM
how'd that happen?
NEXSTAR7 is offline
post #10 of 10 (permalink) Old 01-04-2011, 08:48 PM
taylorb765's Avatar
When I had the car i had some issues with the trigger in the computer shorting out for all the coils on that bank. All the misfires while i was trying to diagnose it most likely melted down the converter and it finally plugged up for him.
Gto Misfire KennedyKustoms Engine Discussions 6 04-21-2010 12:11 AM
New spark plugs? Misfire? WanaGTO Service, Maintenance and Technical Discussion 2 05-17-2009 07:02 PM
