06 Timing Gear Cover - Pontiac GTO Forum
post #1 of 1 (permalink) Old 03-28-2019, 12:01 PM Thread Starter
nardulli's Avatar
Send a message via Skype™ to nardulli
Hey Ya'll,
I'm in the process of installing a FAST 102 intake manifold with a 102 MM Throttle Body, and a Tick Performance Torquer stage 2 cam. While I've got the front of the engine apart, I'm changing out the Oil pump, water pump, alternator, adding upgraded timing chain, pushrods and swapping in dual valve springs. (Mission Creep...)
The new timing gear cover has a different setup than the OEM part. OEM has an odd, square plate on the front and a simple CP Sensor. New part is one piece and has a wiring harness thingy (highly technical word there). See photos. Anyone run into this before?
Name:	timing cover old (2).jpg
ID:	118249   Click image for larger version
Name:	timing cover new (2).jpg
nardulli is offline
1968 GTO set base timing and total timing?? rob40999 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 15 05-27-2018 07:37 AM
Basic Timing Gear Alignment Question EdR 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 2 01-26-2015 10:51 PM
Using Loctite when replacing timing chain upper cam gear RM9700 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 10-23-2014 02:30 PM
grommet from timing gear case to intake man figmoman 1964-1974 Tempest, Lemans & GTO General Discussion 4 11-07-2011 03:00 PM
