1966 Air conditioning - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-03-2018, 12:49 PM Thread Starter
How do you control the idle up speed required when the A/C is turned on?
My car has 3x2bbls added and A/C was not functioning when I purchased it.
It now works, but unless the idle is set to =/-1500, it will not idle.
Winkies GTo is offline
post #2 of 5 (permalink) Old 04-03-2018, 06:37 PM
Quoted: 350 Post(s)
Not 100% sure as never had this problem, but what I do know it that there is an electric solenoid that is typically wired into the AC power and when you turn on the AC, the electric solenoid engages and idles up your carb via a plunger that makes contact on the throttle to open it up a bit more and then will de-activate when you shut down the AC or turn off the key.
I am thinking a Service manual for your car will show this and the wiring.
post #3 of 5 (permalink) Old 04-04-2018, 04:26 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
That's how they dealt with it on the OHC 6 SPRINT engines;
Name:	AC SPEED UP.jpg
ID:	107986   Click image for larger version
Name:	AC SPEED UP 2.jpg
ID:	107994   Click image for larger version
Name:	AC SPEED UP 3.jpg
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #4 of 5 (permalink) Old 05-09-2018, 04:52 PM
GTOJoe66's Avatar
New here, A year ago I bought a 66 with a/c supposedly, The seller said it only need charged, did worry to much about it, The car drove great, rides great, so no issues till I started tearing into it a month ago, had heater core leak, anyway didn’t have any cables hooked up for the heater and air conditioning, figured out the heat cable but not the A/C, As a Beginner, The restoration, Build books haven’t helped me much, Can anyone get me headed in the right direction?
GTOJoe66 is offline
post #5 of 5 (permalink) Old 05-09-2018, 05:06 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
I would look for a good used copy of the Factory AC manual it will go a long way with information.
Name:	66 AC MAN.jpg
1966 gto air conditioning schematic tonyli 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-10-2013 09:48 AM
what air conditioning unit to get bobby326 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 8 07-26-2011 10:44 AM
Air Conditioning Questions HELP Pontiacpurebrred 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 07-05-2011 04:15 PM
Aftermarket Air Conditioning on a '66 hookemdevils22 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 38 05-15-2010 09:48 PM
air conditioning 75coug 2004-2006 GTO General Discussion 19 05-24-2005 09:52 AM
