2 Problems squeaks and keys - Pontiac GTO Forum
post #1 of 3 (permalink) Old 11-04-2008, 12:07 PM Thread Starter
TxSoldier6.0's Avatar
Send a message via Yahoo to TxSoldier6.0
I have 2 problems that hopefully yall can help me with 1.I bought my car and it had a small squeak coming from the belts I was excited to get my car out of the dealership so i figured id spend the 5 bucks on some belt dressing but ive gone through 2 cans of belt dressing and a couple cokes sometimes it works for a while but most of the time it makes the squeak worse any solutions? ........2. Sometimes when I go to lock my doors with the key pad it will chirp 4 or 5 times and not lock the doors i figured it was just a dummy feature tellin me i left a door open or trunk but thats not the case any suggestions?
TxSoldier6.0 is offline
post #2 of 3 (permalink) Old 11-04-2008, 12:30 PM
Welcome to the forum..
The squeak you are hearing is most probably the belt tensioner. Others have reported the same squeak and a new belt tensioner cured it. Try WD-40ing and see if that doesn't stop it.
The chirping may be one of two problems, either a door actuator, or the BCM. Most probably a door actuator.
Hopefully you are still within warranty?
post #3 of 3 (permalink) Old 11-04-2008, 04:06 PM
Aramz06's Avatar
Send a message via AIM to Aramz06
WD-40 was always the cure for the old mercury sables Squeaking.
-LSS Shifter
-Resonator Delete
-Flowmaster 44 Series Mufflers
1 of 475
Aramz06 is offline
