2004 GTO wonít start no spark - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-10-2018, 03:59 PM Thread Starter
Hello all,
I recently purchased a 2004 GTO . I was driving it for 2 weeks no problems. 1 week ago I was driving and it shut off. Everything shut off. Tried to start it would only turnover. I waited for 15 min and it fired up. It did this 2 more times then I had no troubles for 3 days. On the 4th day I drove it 30 min no issue. went back in to go home drove for 15 min again shut off. Had it towed to my house. Sit for 2 days fired up no problem drove it again today shut off. It only turns over. I have no spark and have changed the crankshaft sensor today. Still nothing. Any idea what it may be ? Could it be a camshaft sensor ? Have fuel ,battery has 12.6 v. Donít know what it may be
2004 GTO 5150 is offline
post #2 of 8 (permalink) Old 11-10-2018, 04:22 PM
GTO44's Avatar
Quoted: 37 Post(s)
First thing to do would be:
Check the bcm wiring harness under the passerger side glox box. It comes out of the BCM and makes a 90 degree turn over a metal bracket. They are known to rub thru and start shorting wires out.
Its also possible the bcm is starting to take a poop. Im on my third in 7 years
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 8 (permalink) Old 11-10-2018, 05:16 PM Thread Starter
Are the BIM exspensive ?
post #4 of 8 (permalink) Old 11-10-2018, 05:53 PM Thread Starter
What am looking for in the wire . Do I just wrap with tape ?
post #5 of 8 (permalink) Old 11-10-2018, 06:09 PM
GTO44's Avatar
Quoted: 37 Post(s)
You're looking to see if that bracket has worn thru the wiring harness. If it hasnt it is good practice to go ahead and wrap it with electrical tape for preventative measures.
You can have your BCM fixed at a place called g7computers.com . Mine recently took a poop again. I sent it out to g7 and they fixed it the day they got it and shipped it back the same day. In fact they gaurantee they will fix it the same day you send it. Works for any computer... ie bcm, pcm, ecu, ecm ect. Cost me $225 and the goat is back up and running.
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #6 of 8 (permalink) Old 11-10-2018, 07:03 PM Thread Starter
Will the bcm mess up anything if the car has been tuned ?
post #7 of 8 (permalink) Old 11-10-2018, 07:55 PM
GTO44's Avatar
Quoted: 37 Post(s)
Negative. The pcm is what is tuned. The bcm is just along for the ride
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
post #8 of 8 (permalink) Old 11-11-2018, 05:07 AM
AlaGreyGoat's Avatar
It might give you something to go on, if you had it scanned.
Larry
AlaGreyGoat is online now
No Spark, No start, 66 GTO rick3452 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 18 09-13-2018 06:16 PM
P0335, TCS turns off, and crank/no start or start then die. dlb1982 Service, Maintenance and Technical Discussion 2 10-13-2015 09:57 PM
Passenger door won't lock. Ac won't work, etc 5mgelt1ls2 Interior Discussions 1 11-08-2013 11:09 AM
1970 Lemans/GTO Clone won't start. chris_schenk72 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 27 09-11-2013 07:06 PM
GTO won't start...not firing... offroadfury6 Engine Discussions 4 02-25-2013 05:16 AM
