2004 Pontiac GTO Slave cylinder - Pontiac GTO Forum
post #1 of 4 (permalink) Old 03-22-2010, 08:08 AM Thread Starter
I have been searching for a repair manual or someone that might know the details on how to change the slave cylinder myself on the '04 GTO, but keep hitting a dead end. Mechanics want to charge an arm and a leg to fix it, but I'd rather do it myself. Can anyone help?
rml2007mo is offline
post #2 of 4 (permalink) Old 03-22-2010, 08:15 AM
6QTS11OZ's Avatar
So you're sure you want to drop the trans yourself?
Below are links that help you out as far as dropping the trans and using a F-body slave which is a lot cheaper than the GTO slave. Good luck.
Clutch and Flywheel Install
Install a F-Body Slave on a GTO
~I'm ya huckleberry~
~516rwhp/500rwtq~
6QTS11OZ is offline
post #3 of 4 (permalink) Old 03-22-2010, 08:55 AM
BlackJackByte's Avatar
Yes I've (mostly watched) done this and its very time consuming, luckily I have 2 GM employed mechanics as best friends from college so they done mine for free, parts were still like $425(at cost) for slave cylinder and master cylinder. There was a lot of stuff that came out of my car just to have the space to work. And mine busted on day 3 of ownership, how do you think I felt!!! Good luck!
2004 M6 Yellow Jacket.
BlackJackByte is offline
post #4 of 4 (permalink) Old 03-22-2010, 01:02 PM
If you do it get a friend and a Harbor Freight tranny jack. It's not an impossible job but you'll need some time, a bunch of long extensions and some patience and it can be done. The first time I changed my clutch it took 9 hrs. The last time it was 5.
Clutch Slave cylinder riley70usmc Drive train, suspension, alignment and brakes. 3 12-26-2010 02:21 PM
Hmmm...cylinder 4? Cylinder order??? WanaGTO Service, Maintenance and Technical Discussion 3 07-15-2009 08:07 AM
