2005 GTO bolt Torque Specs - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-15-2016, 03:02 AM Thread Starter
Quoted: 4 Post(s)
Anyone know a website or somewhere to get a PDF on all bolt torque specs on the LS2 engine?
Bryce108 is offline
post #2 of 4 (permalink) Old 07-15-2016, 09:46 AM
GTO44's Avatar
Quoted: 37 Post(s)
Fastener Tightening Specifications
Application
Specification
Metric
English
Camshaft Position (CMP) Sensor Bolt
12 Nm
106 lb in
CMP Sensor Wire Harness Bolt
12 Nm
106 lb in
Camshaft Retainer Bolts - Hex Head Bolts
25 Nm
18 lb ft
Camshaft Retainer Bolts - TORX Head Bolts
15 Nm
11 lb ft
Camshaft Sprocket Bolts
25 Nm
18 lb ft
Clutch Pressure Plate Bolts
70 Nm
52 lb ft
Connecting Rod Bolts - First Pass
20 Nm
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Coolant Air Bleed Pipe and Cover Bolts
12 Nm
106 lb in
Coolant Temperature Sensor
20 Nm
15 lb ft
Crankshaft Balancer Bolt - Installation Pass to Ensure the Balancer is Completely Installed
330 Nm
240 lb ft
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 Nm
37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 Nm
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 Nm
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Crankshaft Bearing Cap M8 Bolts
25 Nm
18 lb ft
Crankshaft Oil Deflector Nuts
25 Nm
18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 Nm
18 lb ft
Crankshaft Rear Oil Seal Housing Bolts
30 Nm
22 lb ft
Cylinder Head M11 Bolts - First Pass in Sequence
30 Nm
22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence
70 degrees
Cylinder Head M8 Bolts - in Sequence
30 Nm
22 lb ft
Cylinder Head Coolant Plug
20 Nm
15 lb ft
Engine Block Coolant Drain Hole Plug
60 Nm
44 lb ft
Engine Block Coolant Heater
40 Nm
30 lb ft
Engine Block Oil Gallery Plug
60 Nm
44 lb ft
Evaporative Emission (EVAP) Canister Purge Solenoid Valve Bolt
50 Nm
37 lb ft
Exhaust Manifold Bolts - First Pass
15 Nm
11 lb ft
Exhaust Manifold Bolts - Final Pass
20 Nm
15 lb ft
Exhaust Manifold Heat Shield Bolts
9 Nm
80 lb in
Exhaust Manifold Studs
20 Nm
15 lb ft
Flywheel Bolts - First Pass
20 Nm
15 lb ft
Flywheel Bolts - Second Pass
50 Nm
37 lb ft
Flywheel Bolts - Final Pass
100 Nm
74 lb ft
Front Cover Bolts
25 Nm
18 lb ft
Fuel Injection Fuel Rail Bolts
10 Nm
89 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Stud
12 Nm
106 lb in
Ignition Coil-to-Bracket Bolts
10 Nm
89 lb in
Intake Manifold Bolts - First Pass in Sequence
5 Nm
44 lb in
Intake Manifold Bolts - Final Pass in Sequence
10 Nm
89 lb in
J 41798 M8 Bolt
25 Nm
18 lb ft
J 41798 M10 Bolts
50 Nm
37 lb ft
Knock Sensor Bolts
20 Nm
15 lb ft
Motor Mount Bracket Bolts
50 Nm
37 lb ft
Oil Cooler Bolts
12 Nm
106 lb in
Oil Filter
30 Nm
22 lb ft
Oil Filter Fitting
55 Nm
40 lb ft
Oil Level Indicator Tube Bolt
25 Nm
18 lb ft
Oil Level Sensor
20 Nm
15 lb ft
Oil Pan Closeout Cover Bolt - Left Side
9 Nm
80 lb in
Oil Pan Closeout Cover Bolt - Right Side
9 Nm
80 lb in
Oil Pan Cover Bolts
12 Nm
106 lb in
Oil Pan Drain Plug
25 Nm
18 lb ft
Oil Pan M6 Bolts - Oil Pan-to-Rear Oil Seal Housing
12 Nm
106 lb in
Oil Pan M8 Bolts - Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 Nm
18 lb ft
Oil Pressure Sensor
35 Nm
26 lb ft
Oil Pump Cover Bolts
12 Nm
106 lb in
Oil Pump Relief Valve Plug
12 Nm
106 lb in
Oil Pump Screen Nuts
25 Nm
18 lb ft
Oil Pump Screen-to-Oil Pump Bolt
12 Nm
106 lb in
Oil Pump-to-Engine Block Bolts
25 Nm
18 lb ft
Spark Plugs
15 Nm
11 lb ft
Throttle Body Bolts
10 Nm
89 lb in
Timing Chain Dampener Bolts
25 Nm
18 lb ft
Valley Cover Bolts
25 Nm
18 lb ft
Valve Lifter Guide Bolts
10 Nm
89 lb in
Valve Rocker Arm Bolts
30 Nm
22 lb ft
Valve Rocker Arm Cover Bolts
12 Nm
106 lb in
Water Inlet Housing Bolts
15 Nm
11 lb ft
Water Pump Bolts - First Pass
15 Nm
11 lb ft
Water Pump Bolts - Final Pass
30 Nm
22 lb ft
Or Attached is 2 pages from the 2005 gto helms manual.
ID:	78930   Click image for larger version
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 4 (permalink) Old 07-19-2016, 01:37 AM Thread Starter
Quoted: 4 Post(s)
Wow, Awesome thank you very much!
Bryce108 is offline
post #4 of 4 (permalink) Old 07-19-2016, 08:48 AM
GTO44's Avatar
Quoted: 37 Post(s)
No prob!
2006 GTO M6
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
GTO44 is online now
400 ci 4 bolt main torque specs Shake-N-Bake 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 14 11-29-2015 07:04 PM
valley pan bolt torque specs JohnGoat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 09-15-2015 02:52 PM
2004 GTO Steering Wheel Nut Torque Specs Badkat Service, Maintenance and Technical Discussion 3 09-19-2014 09:45 AM
Torque Specs Getyourgoat 1964-1974 Tempest, Lemans & GTO General Discussion 6 09-08-2014 05:36 AM
Torque specs 66goatframeoff 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-08-2012 01:33 PM
