2005 GTO Dyno with LPE CAI - Pontiac GTO Forum
post #1 of 13 (permalink) Old 08-06-2005, 10:36 AM Thread Starter
Dynoed my car the other day with LPE CAI installed. I only had 765 miles on the car when it was dynoed. Best run was 349.7 HP 346.7 TQ. I was pretty happy with those numbers now I can't wait to get my Long Tube headers and tune done. I hate that these cars will not break the tires loose during 1st to 2nd gear shift. I know it is the stock tune that is doing that.
Robw_29 is offline
post #2 of 13 (permalink) Old 08-06-2005, 11:02 AM
Your HP numbers look good.... I think you are a little low on the TQ side
I am not sure why that is the case with your car. I can break the tires loose on my car from 2nd to 3rd consistently. And I can get a chirp "on-demand" at 70... to impress my friends
I also drive with "T/C" off. Was that off when you Dyno'd ?? It could make a difference.
Anyway most 2005 GTO's are dynoing around 335-345 WHP / 340-350WTQ...... Just with the LPE alone you should get around 355 WHP and 360 WTQ (guess-timating). I have not dyno'd my car yet but I hope to get better numbers.
LS2FAST is offline
post #3 of 13 (permalink) Old 08-06-2005, 11:48 AM Thread Starter
I only had 765 miles on the car. I think my numbers are right on par with CAI they don't do much for you on a dyno in the first place. I also think once my car breaks in more the numbers will go up. I will never really know for sure since in 2 weeks I will have LT headers magnaflow catback and be dyno tuned.
Robw_29 is offline
post #4 of 13 (permalink) Old 08-06-2005, 11:55 AM
Yeah could be... I have 6,500 + miles on my car. That is going to be sweet when you are all done.
LS2FAST is offline
post #5 of 13 (permalink) Old 08-06-2005, 12:14 PM Thread Starter
All done? Is there such a thing . Once the exhaust is done then I go cam shopping. Then maybe gears, wheels, and whatever else I can think of or should I say afford.
Robw_29 is offline
post #6 of 13 (permalink) Old 08-06-2005, 12:28 PM
derf's Avatar
I can break the tires loose on the 2-3 shift in my stock '04...
You might have something wrong with yours.
derf is offline
post #7 of 13 (permalink) Old 08-06-2005, 12:46 PM
Has anyone actually dynoed the increase with their LPE CAI? I just put mine on and I was wondering if it works as well as they say...sounds good though
YouHolden? is offline
post #8 of 13 (permalink) Old 08-06-2005, 03:59 PM
fergyflyer's Avatar
Robw 29 is your car an a4? The torque management should not affect the m6. I can break mine 1-2, 2-3, and get a little chirp 3-4. I've gat a m6.
fergyflyer is offline
post #9 of 13 (permalink) Old 08-06-2005, 05:35 PM Thread Starter
My car is a 6spd. Not sure what is up with my car it only 900 miles on it so I have not really tried all that hard to break the tires loose on the 1 - 2 shift. I think it is performing as it should be it pulls real hard just seems to be pulling timing between shifts. If it is the TM issue it will be gone for good in about 2 weeks. It also might just be the weather effecting the car I can tell this thing really hates heat. I know all cars hate it but this car seems to be effected by heat more then any other car I have owned. That will be corrected in about 2 weeks also with the dyno tune.
Robw_29 is offline
post #10 of 13 (permalink) Old 08-06-2005, 05:58 PM
fergyflyer's Avatar
To help with the heat issue I removed the hood plugs and took the fuel rail covers off. I want to get a 12.5 before I start modifying, so I'm waiting till January to do a 160 thermostat and change the settings on the fans. Those are some ideas for you. It really does hate heat though, just playing at the track I've noticed almost 1 second and 5 mph in difference from 60 degrees to 90 degrees.
