2005 GTO problem - Pontiac GTO Forum
post #1 of 9 (permalink) Old 07-22-2005, 02:52 PM Thread Starter
2005 GTO problem
I'm new to this forum. Anyone else having a problem with their 2005 GTO and the throttle position sensor? I have had 2 replacements and I have only 3500 miles.
redhead is offline
post #2 of 9 (permalink) Old 07-22-2005, 05:54 PM
PPS seems to be a bigger problem, but they are all interconnected on a FBW system.
silvergoat05 is offline
post #3 of 9 (permalink) Old 07-24-2005, 08:39 AM
Yep, mine was replaced at about the same mileage. I have 10,000 miles on the car now, havent had a problem since. Actually, the repair ticket stated the gas pedal assembly was replaced.
Last edited by 05impulsegoat; 07-24-2005 at 08:40 AM. Reason: To further clarify what was repaced according to the repair ticket.
05impulsegoat is offline
post #4 of 9 (permalink) Old 07-25-2005, 03:19 AM
Had the same problem on my Z06 when I bought it. Was replaced under warranty and has worked well since. Hope yours lasts this time around.
Subdriver is offline
post #5 of 9 (permalink) Old 07-24-2008, 05:02 PM
aarons1k's Avatar
What symptoms were you guys having with the 05 gto with the tps? I think i am having a similar problem...
aarons1k is offline
post #6 of 9 (permalink) Old 07-27-2008, 09:21 AM
I'v had two throttle position sensors replaced on my car also. Seems to happen to alot of us...Vette owners also.
STLGTO05A4 is offline
post #7 of 9 (permalink) Old 07-29-2008, 07:58 AM
What symptoms are you having?
With the TPS, the car goes into "Reduced Performance Mode" (shows up on the dash) and let me tell you, the performance is severely reduced. It's like idling up to speed.
Happened to my car with about 3500 miles on it. A couple of starting cycles later and it cleared and was fine while I waited to couple weeks for the replacement part, and it was all covered by warranty. Been fine ever since. (@53k now)
Ninjured is offline
post #8 of 9 (permalink) Old 07-29-2008, 05:23 PM
aarons1k's Avatar
real rough idle, some time u cant drive it, i just had it in the dealer and they replaced the Mass air flow sensor , i have only had it back for 2-3 days , just trying to make it sure that fixed it.
aarons1k is offline
post #9 of 9 (permalink) Old 08-09-2008, 07:04 AM
LOWET's Avatar
I have had that problem with other GM vehicles but never with my GTO. Had my 05 GOAT for 3 1/2 years without one problem. I don't drive it a lot. It has 12,850 miles on the clock.
447 CI forged stroker [ 7.3 liter ] 6 Bolt main caps
Holley Modular Mid rise Intake Manifold.
F1 Procharger ,
Just way too much to list,
LOWET is offline
