2005 Throwing up code P0604 (Control Module RAM fault) - Pontiac GTO Forum
post #1 of 7 (permalink) Old 07-30-2012, 05:33 PM Thread Starter
Check engine light came on today. Ran the code and it came up with P0604.
"Definition- Control Module Random Access Memory (RAM) fault
Explanation -ECM detected the internal data test failed (RAM)
Probably Cause- Failed ECM"
Anyone have any idea what that could be? My car only has 27k miles on it. Id appreciate any advice in case its something I dont need to pay the shop to do.
rezarxt is offline
post #2 of 7 (permalink) Old 07-30-2012, 05:58 PM
If it's a failed ECM then you're going to need the dealer. You're going to need a new ECM and a Tech II to connect it up to the other modules. You could try disconnecting the battery for 15 minutes and rehook it up. Maybe it is a one time glitch.
post #3 of 7 (permalink) Old 07-30-2012, 07:41 PM Thread Starter
Tried it. No luck.
rezarxt is offline
post #4 of 7 (permalink) Old 07-30-2012, 08:35 PM
Your Engine Controller is shot.
Get a new one and have it reprogrammed by the dealer.
LS2 MN6 is offline
post #5 of 7 (permalink) Old 07-31-2012, 07:29 AM Thread Starter
Any difference between A1 cardone and AC Delco ECM's?
Pontiac GTO Engine Control Module - Free Shipping - A1 Cardone, AC Delco
rezarxt is offline
post #6 of 7 (permalink) Old 07-31-2012, 09:16 AM
It sounds like the Cardon unit is a reman but I wouldn't be afraid of that at all. Electronics that have been cycled can be better than new untested ones. It has a warranty and if it lives through that it will probably outlive the car.
post #7 of 7 (permalink) Old 08-04-2012, 10:23 PM
ecm question
Can the ECM cause a hard shift? I guess my question really is can the ECM mess how the transmission shifts and the traction control?
z28gto is offline
Fault code The intimidator Service, Maintenance and Technical Discussion 1 11-23-2010 07:27 AM
Just got a 2005 gto and when to turn traction control on or off?.... pctek 2004-2006 GTO General Discussion 5 07-21-2010 09:58 AM
Fault code The intimidator Service, Maintenance and Technical Discussion 2 03-09-2010 02:04 AM
Control Module Internal Proformance? Michael.Narlock Service, Maintenance and Technical Discussion 2 01-06-2009 08:01 AM
2005 Traction Control bogie1 Service, Maintenance and Technical Discussion 3 02-19-2005 08:32 AM
