2006 - Engine hesitating / slipping - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-21-2013, 03:30 PM Thread Starter
Hey everyone,
I just bought a 2006 GTO with a couple performance mods (magnaflow exhaust, cold air intake) about 3 weeks ago. I noticed that the engine sputters a little bit when I'm starting the car. Also, while i was driving about 20 mph, the engine slipped a little bit and although I was pushing the accelerator, the RPM's weren't going up and the car wasn't speeding up. It went away after about 5 seconds and I haven' seen it since (happened yesterday).
Things that might be important:
I noticed that a pretty big chunk (4-5 in) of the the catalytic converter had become dislodged and made its way all the way to the right exhaust tailpipe. I pulled it out. It had already passed emissions and no check engine lights came on.
This happened right before I drove the car on a long road trip (Atlanta to NY).
Now, when I start the engine, it has a sort of delayed reaction that is a bit more quiet than the original 'roar' that i heard the first week I had the car.
Any ideas what might be causing it? Maybe a fuel pump issue?
Thanks a lot.
Alejandrodizzle is offline
post #2 of 2 (permalink) Old 07-21-2013, 07:26 PM
AlaGreyGoat's Avatar
If it were mine, first, I would get it scanned to see if any specific codes are set.
Then, I would replace the spark plugs and maybe the wires.
Last, I would run a few tanks of gas with a good injector cleaner in them.
There have been soooo many owners replace their stock manifolds with headers, that a used cheap set of stock cats should be an easy find.
AlaGreyGoat is offline
New Centerforce Clutch Slipping Texas Goat 2004-2006 GTO General Discussion 3 04-14-2013 02:20 PM
Brakes Slipping Masterdutch Drive train, suspension, alignment and brakes. 7 11-05-2010 12:14 PM
Car is hesitating bigsam55 Service, Maintenance and Technical Discussion 10 08-12-2010 08:07 PM
hesitating simmons68 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 08-08-2010 07:18 PM
Transmission slipping??? TORNATIC!! Drive train, suspension, alignment and brakes. 0 07-10-2008 06:48 AM
