2006 gto clutch leaking. need advice - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-21-2013, 10:12 PM Thread Starter
I have a 06 and I lost pressure in my clutch the other day . I bleed. The clutch but it just leaked out. I assume its the slave cylinder. How hard is it to change. Any advice appreciated. Also seen it leaking out of the bell housing after I bleeding
sailfish is offline
post #2 of 3 (permalink) Old 12-22-2013, 07:04 AM
trues607's Avatar
You'll have to pull the transmission to remove the slave cylinder.
trues607 is offline
post #3 of 3 (permalink) Old 01-02-2014, 06:50 AM
Was it leaking before you bled it? Did you make sure to tighten the bleeder back up all the way? Just tryin to save you some trouble before you have to pull the trans...I hate doin that...its a pain.
bigdeezs is offline
a LITTLE coolant leaking from my new 05 gto wfsrde Service, Maintenance and Technical Discussion 7 11-10-2012 07:57 AM
Clutch Swap 2010 z06 into 2006 GTO Phantom black 2006 2004-2006 GTO General Discussion 0 12-03-2011 10:06 PM
Advice on buying 2006 GTO Yalie GTO 2004-2006 GTO General Discussion 14 03-31-2006 06:41 PM
Just Ordered A 2006 GTO Need Advice 2006GTO Service, Maintenance and Technical Discussion 28 12-13-2005 04:23 AM
