2006 gto overheats - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-17-2015, 09:17 PM Thread Starter
2006 gto overheats
I changed my oil and a lower radiator hose and now my car over heats. Can anyone help me out???
eastoakland900 is offline
post #2 of 5 (permalink) Old 06-17-2015, 11:27 PM
Steamwalker's Avatar
Burp the coolant?
06/QSM/A4
SoCal Goat Club
Steamwalker is offline
post #3 of 5 (permalink) Old 06-18-2015, 12:53 AM
Changed oil, engine overheats...
Experienced that recently, I was noticing drippings size of a table plate every am. Coolant level low warning comes on, radiator is on full, would top reservoir, after a few days, the same thing. Didn't want to have more problems, my mechanic replaced water pump and thermostat. It's been more than a month now, situation normal.
luis v esquillo is offline
post #4 of 5 (permalink) Old 06-18-2015, 07:46 AM
Check your lower hose to make sure its not sucking closed. It could be sucking closed causing a circulation issue. If you discover this, get a hose spring and insert it in the hose to prevent this. Not all hoses are created equal, thin wall hoses will pinch nearly shut, an older OEM hose will loose its stiffness over time and have pinching issues.
Your system may have gotten air in it and the thermostat is not operating normally and may need "burped" to clear the air bubble.
post #5 of 5 (permalink) Old 06-20-2015, 08:29 PM
If the system has air in it you'll need to disconnect the rubber hose to the crossover pipe at the top of the cylinder heads. while disconnected, add antifreeze mixture until it begins to exit the crossover tube, Reconnect the crossover tube rubber hose, top off the radiator and verify correct level in the receiver tank. Check daily for a few days and top off if necessary.
TNGTO is offline
LS9 Crate into 2006 GTO, degree of difficulty? 9"Moser replacement for stock GTO IRS tem2006LS2plus Engine Discussions 23 07-14-2011 06:26 PM
My 2006 LS4 W Body vs. my 2006 LS2 GTO... LittleMT Racing and Kill Forum 7 11-17-2006 05:28 PM
Project GTO - 2006 Torrid Red Pontiac GTO - MacMini Carputer - Streetdeck Mickey21 2004-2006 GTO General Discussion 0 07-11-2006 02:00 PM
Project GTO - 2006 Torrid Red Pontiac GTO - MacMini Carputer - Streetdeck Mickey21 Interior Discussions 10 07-11-2006 01:57 PM
