2006 Hard Starting - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-22-2015, 11:25 AM Thread Starter
2006 Hard Starting
OK sorry if this has been discussed, but I just spent a hour and can't find it. I just bought a 06 and it seems to turn over slow and hard. It had a 650cca battery in it that works fine in my truck so for shits and giggles I took my 800 cca battery and stuck it in there same problem. Sounds like the battery is going dead or very weak. When the car is hot same problem maybe even worse where you crank it and it doesn't go then wait a minute and it starts but very slow turning over. Any ideas?? Thanks in advance.
raca65 is offline
post #2 of 2 (permalink) Old 10-22-2015, 03:48 PM
If your battery was fully charged when you tried it it sounds like a poor connection or the starter. If it sat for even a few days these cars are energy vampires and fairly quickly discharge batteries. I put mine on a trickle charger when I'm not driving it.
Hard starting when hot(ish) gjones 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 05-02-2013 10:59 PM
Hard starting after driving mshidner 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 19 06-21-2010 05:36 PM
Hard starting 66 paly57 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 14 10-19-2009 09:39 PM
used 2005-2006 GTO hard to find thecommish16 2004-2006 GTO General Discussion 7 11-21-2006 01:09 PM
hard cold starting my1971gto4spd 1964-1974 Tempest, Lemans & GTO General Discussion 3 04-10-2006 07:19 PM
