2nd Gear Popping out when downshifting - Pontiac GTO Forum
post #1 of 1 (permalink) Old 11-23-2013, 06:45 PM Thread Starter
Sup guys having an issue here where only when i try to down shift to second it pops out and this is occasional, but if i slow down to like 5-15 mph it won't pop out. It doesn't grind like a synchro but it will make a horrible noise like the gear itself is grinding if i try to hold it in while letting the clutch out above 5-15 mph. Would the shift fork being messed up cause this problem? If so why only in second gear? I don't have issues downshifting or up-shifting on any other gear. I had the clutch assembly replaced about 1 and a half months ago in which I've have had the car for 3 months now. Though this issue has been around since before the replacement clutch. It's an 06 with 37,XXX miles on it. Any thoughts on what it could be?
prayforgray01 is offline
into 2nd gear Nate Wheels and tires 12 06-16-2010 02:06 PM
Will not go into 2nd gear? crccobra 2004-2006 GTO General Discussion 7 02-14-2007 01:34 PM
2nd Gear Problems MACHINE HEAD Drive train, suspension, alignment and brakes. 14 07-26-2006 07:04 PM
Popping Out of Gear jskwarek 2004-2006 GTO General Discussion 6 12-27-2005 10:58 AM
2nd gear skip GTO JUDGE 2004-2006 GTO General Discussion 3 06-04-2005 08:04 AM
